I don't see it either..
Printable View
Hmmm It is right there in the AppMart, I just downloaded it to make sure it is working. And yes, it is zipped this time, just like it says in the store, it must be unzipped then run the .exe
>>>>>> Here it is in the AutoApp Mart <<<<<<
Got it! Thanks. (was looking for 5.1.0)
Will the old donation patch for DFX5 work with this new edition or will I have to buy new one?
Go to app mart and after you login go to My Account and you will see all the previous purchases and there click at the "Version 5.1.0.R available" after the DFX5.0.3 Loader Patch and it will start downloading.
Hope that i helped you because my english are poor...
Correct, that is a plus of the store, once you purchase something it remembers it and if that particular item get updated, it will allow you to download for free, the update as you have already paid for it.
if you already purchased the 5.0.3 donation patch, and you plan on updating via the skin update patch, you will not need to download the newer donation patch as the update patch will update your skin keeping it in same state it was before updating.. meaning if you you apply the update to a registered skin then it will still be registered after the update. We did this to help eliminate steps for users when they updated, otherwise, they would have had to dl both the update patch and the donation patch, install the update patch and after install the donation patch. So this helps to keep it much simpler for them...
Thanks for the update guys, John thanks for the bird logo, looks pro.
One small prob. though........For RRVoice, it does not mute when saying commands now.
Something I'm missing??
Attach a RR debug log...
Blue, sorry I should of known better......Here ya' go.
Also I notice that I get no greeting @ start up, but when I click on the music button my greeting starts to play.
EDIT:
I applied the update patch to my win "7" PC and now the vol+ vol- don't work and the mute button does nothing either.
I then thought maybe RRVoice had something to do with it, being that there may a conflict with "7" OS & RRV.
So then I unregistered RRV to see if this was the problem, but it wasn't.
Also, when I use the volume dial on the laptop, no matter what I do to lower or rise the vol., it always goes back to 50% when DFX is in full screen.... but when I minimize DFX, the vol. dial works and does not stay on 50%.
Then if I maximize DFX the volume goes back to 50%???? :ohwell:
Maybe this has something to do with GPS & vol control? I don't have GPS installed on this machine.
Here is the debug from this win"7" lappy. Thanks blue. :o
