I've had the same problem. It's because speedatt is enabled for some reason. Checked your RR.ini and make sure speedatt is set to false. Then check skin.ini and make sure it says "speedatt=false". Skin.ini will probably say "speedatt= " when you check it, so you need to add the false to it. That should fix it.
