View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1081
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by RAWPWR View Post
    I applied the update patch to my win "7" PC and now the vol+ vol- don't work and the mute button does nothing either.
    Also, when I use the volume dial on the laptop, no matter what I do to lower or rise the vol., it always goes back to 50% when DFX is in full screen.... but when I minimize DFX, the vol. dial works and does not stay on 50%.
    Then if I maximize DFX the volume goes back to 50%????
    I've had the same problem. It's because speedatt is enabled for some reason. Checked your RR.ini and make sure speedatt is set to false. Then check skin.ini and make sure it says "speedatt=false". Skin.ini will probably say "speedatt= " when you check it, so you need to add the false to it. That should fix it.
  2. #1082
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    I'm having a different volume problem that is driving me nuts. I'm about to uninstall everything and start from scratch, and reload XP too if necessary.
    Basically, any audio transition (song ends and change to next song, pick an internet radio station, etc.) causes the audio to drop out. Usually I can then go into the Mixer screen and touch the WAV slider (which is at 100% BTW) and just changing it a bit will fix things. But I have had to go to the Windows advanced audio controls more than once to restore sound. Sometimes both the Bass and Treble sliders will drop all the way to zero. Today the BAL got set to Left only.
    Something is clearly not being set up and changed properly with regard to audio. I'm using WinAmp (current as of a month ago) with the linein plugin, could that be the culprit? I'd gladly change to WMP or Foobar if they are preferred now.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  3. #1083
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Quote Originally Posted by kbreeden View Post
    kbreeden, speedatt is set to false in rr.ini........... Not a clue on this one bud.
  4. #1084
    Raw Wave
    Jun 2002
    Virginia
    Reread my post. You need to check skin.ini in the DFX folder as well. I have had this issue 2x and each time I have added the word "false" after "speedatt = " in skin.ini and it has fixed the problem. I'm certain that's what's going on with you.
  5. #1085
    May 2007
    Thumbs up
    kbreeden, "speedatt =false " in skin.ini.......that did it!, Thanks a bunch.
    Now my startup greeting works again too!??
    And I don't have to click on the music button either.......I wonder if "speedaatt" is messing up the start up greeting in some way?
    Next question is why does this happen?
    On a lighter note, for bird owners like myself....I added a few more colors using Photoshop and Johns Firebird/TA icon, being my bird is red, so it was only natural...Thanks again John!
    Attached Files Attached Files
  6. #1086
    Apr 2011
    John, Blue and all the Beta Testers, great job on the updated skin, well worth the wait. Love the Random Play button.Still some kinks, but I'm new to this having just installed my first car pc last month. Once I get around to it I'll start tinkering with adding skins and buttons for the plugins not yet skinned in DFX.
    Things to do:
    Add Button for listen on main menu for RRVoice
    Add Skin for RRTube
    Add Skin for Web Browser
    Mobilephone.net integration
    Winamp Visualisations (some works some dont)
    If you have any advice for a newbie to point me in the right direction without having to go through 10000+ posts, please share.
    Again, thanks alot for all your hard work and have a well earned rest.
  7. #1087
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by Adesh Gayah View Post
    Things to do:
    That button is already there, or at least it was on 5.0.3, I should know.
    There is an RRVoice icon on the top status bar, press it and RRVoice enters listen mode.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  8. #1088
    Nov 2009
    Just got this error on a fresh install of riderunner and dfx 5.1 Not sure what it is all about. It seemed to finishe the install after all.
  9. #1089
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I will check on the full installer about the speedatt setting and fix if needed.
    Quote Originally Posted by themlruts View Post
    What flavor of XP?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #1090
    May 2008
    San Jose, CA USA
    Is there anyone that can help me with my issue on the new release. When I hold down the bottons to change them the screen comes up to change it. I select the button and it sets the path correctly but the button icon doesn't change. EXAMPLE: The button was GPS and I selected sirius. when I press the button which has the GPS icon still on it takes me to my sirius radio page. Anyone having this issue?
    Also how do I make less menu pages...6 is too many for me. I liked 2 in the previous versions.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
