Is there any way to put a spectrem analylzer in the center of the screen like where the log goes. somthing like this
Ok, I actually decided to fix the issue the correct way, in the actual RRMedia PI. It will now set the source to audio if it is now audio after loading the disk. See bottom of Post #2.I think i know why, basically, RR doesn't set itself to a source if you don't go to a source screen first, hence why it works when you go to the old school browser, it knows and sets its source to Audio(mp3) and then the TAGxxx and album art work accordingly. And is fixable via the skin.Originally Posted by drewbp
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
For US users, should we move to RR Fuel Prices or stick with RRGAS?
Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
CAR: 2007 G35 Sport Coupe 5AT
HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
RRFuel prices has replaced RRGas, as far as I know. I will let Enforcer jump in here and answer that one....
Yes, but you can only have one single "App Area" defined at a time, in any skin. So find the line in the menu.skin (as well as in menu's 2,3 & 4) and find This line:
Z,14,7,772,121
Replace it with this line:
Z,246,165,305,274
This simply moves the visual from the top, to the center. You can move it where ever you want really. How it is defined breaks down like this:
Z,Distance From Left,Distance From Top, Width, Height
I just tested it here, and it will work on top of any of the menu options, weather, photo, 2D, 3D logo ect...
My Fiero Build Thread
As per the FAQ's in the FuelPrices thread
Other considerations though;Originally Posted by me
In RRFuelPrices all the settings are now done within RR itself, so no editing of ini files is required.
There are a couple more navigation program options (used to navigate to a fuel station of your choice) in RRFuelPrices that aren't in RRGas. So if you use Sygic or iGo8 as you navigation program RRFuelPrices will be better for you.
As you have posted in the DFX thread I assume you are using DFX5. Now I am not sure if DFX now comes with RRGas skin files or RRFuelPrices files or both, maybe John can answer that one.![]()
Currently DFX 5.1 still comes with RRGas skin files and a preset button for it. I dl'ed RRFP and installed it but stopped short of manually setting up a button for it. I raised the question because the RRFP skin was done before 5.1 was released and I didn't want to break something that was already working.
To be honest I'm chasing several issues in my carpc right now so causing another problem just wasn't high on the list. If it's supposed to work okay then I will go for it.
If I remember they are both in there btn wise. Look in the btn chooser
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Remember that retro Pergresso pasta sauce commercial............It's in there!![]()
Well I *DID* look... must have missed it! Doh!
