View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1241
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not really sure what/why you went backwards with WA?? We do recommend the latest n greatest WA version. As far as the installer, no not yet, was not home most of the weekend.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1242
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    Well for some reason yet to be determined, when I have the most current WA installed W/ DFX5.0.3 and then the 5.1 patch my system runs slow (among other things strange). I get a 3-4 second lag when I access any button in the skin. So I am back tracking trying to find what is not playing nice.
    For now I have RR 4-01-11 running DFX5.0.3. All is well (no lag time) except, I can't get the 5.1 patch to install. The installer can't find my RideRunner installed file folder.
  3. #1243
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Quote Originally Posted by nhra no 2 View Post
    Make a copy of your RR folder, rename the DFX5 folder to something else, then install 5.1 straight up w/o patching and see if you get the same problem.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  4. #1244
    Aug 2006
    Aurora, IL
    Zogg
    When I make the copy off my RR folder, is this just as a backup? And by renaming my installed DFX-5.0.3, is this a backup as well? Kinda sounds redundant.
    (Charger) Zotac IONX-B-E (Atom sing core) w/ 2gig ram Xenarc 705, M2-ATX, XP, RR&DFX5
    (Mustang) ECS mini-ITX (Atom dual core) w/ 2gig ram, Lilliput 809, M4-ATX, XP, RR&DFX5
  5. #1245
    Constant Bitrate overlander's Avatar
    Feb 2008
    I'm having an interesting issue. I have the May release of RR and the 5.1 patch for DFX5. all on windows home edition. I'm using MS Media player for my music source (as winamp any version keeps crashing on me for some reason that I can't resolve). player works fine for music, and my visteon HD player also works fine until I hibernate. If I go into hybernation with the HD radio playing, when the PC recovers from hibernation, the HD radio skin will list the last active music playlist in the radio preset box, and won't play any radio at all. I actually have to navigate out of HD radio to music, then back to HD radio, to get it to play and list presets correctly. it does this now consistently everytime. It did not do this prior to 5.1, so I'm not sure what the root cause of fix is. Any ideas what to check?
    Update: I resolved my issue be reactivating Resume from Hibernation in the RRconfig utility.
  6. #1246
    Apr 2005
    Plano, TX
    Zogg
    Yes, for backup. This way you have 2 chances to get back to where you were. I like redundancy, especially when it's easy.
  7. #1247
    Jan 2009
    Need a little help
    I just have installed DFX 5.1.0, but when i try to change a playlist, i choose the the play list i want and then nothing happens.
    The playlist is not changing and i still hear the previous songs. Is there a setting that i have to change???
  8. #1248
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, but your description of your issue is not very detailed. Because sometimes users mixup terms it is hard to give advise for a solution, not knowing exactly what the user is asking about. Try telling how you are navigating to the screen in question and then hopefully someone can help with a answer.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1249
    Apr 2005
    Plano, TX
    I installed the Internet Radio update and was playing with it, and one of the buttons tries to load a skin that isn't there, Internet_Radio_Loadplaylist.skin. I was trying to pull up the list for my state, which I assume this skin lets you do.
    I dl'ed again and it's still not there, so is that part not completed yet?
    Cheers!
  10. #1250
    Apr 2005
    Plano, TX
    Another question: Is there a way to have RR/DFX open on a different skin other than the first menu skin? Most of the time I'm in an iGuidance screen (the exact skin name escapes me but I can get the name) so I'd like to have DFX start to that screen. Just need to know where to specify if it's possible.
    If it's not possible, then consider this a feature request. Thanks!
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
