View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1311
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    Blue, I understand that. I meant no disrespect with the bloated comment. It is just that I noticed a dramatic slow down when I went from 5.0 to 5.1. I am just trying to figure out if I have a RR & DFX install - config problem, a Windows XP, and/or hardware problem. I am trying to look at this problem from many ways, and not trying to get lost in the process.
    (Charger) Zotac IONX-B-E (Atom sing core) w/ 2gig ram Xenarc 705, M2-ATX, XP, RR&DFX5
    (Mustang) ECS mini-ITX (Atom dual core) w/ 2gig ram, Lilliput 809, M4-ATX, XP, RR&DFX5
  2. #1312
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    no offense taken in any way. DFX is a pretty complex skin for sure, and there is a lot of stuff running under the hood. It has been done, as Blue said, as efficiently as possible. I would start by disabling/un-registering some of the plugins in the RideRunner\Plugins folder, and see if that makes a difference. That is a great place to start at least. If not, then you can rule one thing out. Check out the sticky in the root RR forum for how to speed up RR. There are some pretty good tips in there, that I gathered from personal experience, as well as from other threads on the forum.
    My Fiero Build Thread
  3. #1313
    Oct 2007
    Quote Originally Posted by nhra no 2 View Post
    I have noticed that DFX5.1 takes longer to get to the main screen. For some reason DFx5.1 start up feels its taking twice as long as before. Haven't noticed any slow down after it completes loading though.
    This is a fresh install of WinXP SP3 + RR + DFx. Dual core laptop, SATA HD, 2GB RAM
  4. #1314
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    have any of you guys updated or installed any plugins recently,,, might answer a few things,,, i would disable all external PI's and just run dfx default install ,, see what the difference is ,, then enable each PI,,, until it slows up,,, alot of plugins check things on rr start up , slowing the process...
    recheck all your settings make sure you don't have something switched by mistake , like scan database on start up , if there is such a setting IDK...
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  5. #1315
    Aug 2006
    Aurora, IL
    John,
    I know how to disable a plugin from within the skin on the plugin manager screen. But what do I need to do to un-register them? Is it as simple as running the command prompt in XP, and un-registering the plugin dll file? Or is there more to it?
  6. #1316
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That would be the way to totally make sure that the plugin is disabled, with no questions if its still doing something or not, depending on how the PI was written.
    I know that some PI's have an unregme.bat type file with the dll that could be used to keep from typing those out.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #1317
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Any chance of getting the new DFX.dll to get the cover art browser working again. Last time I checked it was not in the post #4 download file. I have not updated RR in my car the last 2 releases due to this issue.
    Thanks.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  8. #1318
    MySQL Error
    Oct 2004
    Quote Originally Posted by silvi4000 View Post
    a lot of songs in the playlist would do this, specially if winamp is set to do titles(tags) when files are LOADED into winamp!!!
    even without this a lot of songs in the playlist would slow startup down...
    so.. i suggest clearing the PLaylist before you exit, and then eval the startup time...
    just to rule that out
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #1319
    Aug 2005
    Iceland
    When installing DFX5.1 i get error saying that "mscomctl.ocx" is missing. Any ideas?
    Also the install of DFX5.1 wipes out my RR settings, i have to redo them
    2005 VW Passat FSI 2.0
    Iceland
  10. #1320
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Roadwarrior
    Odd. Using one of the striped down Window flavors, if so which one?
    It Has been tested with TinyXP Rev9.
    Shouldn't, the only thing that the installer would do is to set your skinpath/nightskinpath if you leave the "Set RR to use this skin as..." options during the install process.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
