View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1331
    MySQL Error
    Oct 2004
    Quote Originally Posted by themlruts View Post
    Thanks mitch
    I will just most likley write a quick little vbscript with wait cmd or maby write it so it waits until usb are inialized. I am using a usb to serial adapter. What do you think that problem is whith the radio skin that it shows music and then if i go to menu and then back in it works fine?? Kinda wierd. The music that is listed is the the alblum i have loaded in winamp.
    ok, that is due to the fact a PLAYLIST on the MENU SKIN...(should be handled).... can i ask what build of rr? 5/7 or 7/5?
    i can set up too and double check
    on 1st shot.. mine is OK.. running DFX5.1 with some fixes (not sure if they out, but i dont think related to menu.skin)
    7/9/2011 build of RR
    what is ur ResumeMusic= in rr.ini?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #1332
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thanks mitch
    Check out StartUp Delayer. It is a nice and powerful little program. It will let you optomize how windows starts files when it boots up. You can delay anything that windows starts when it boots up, and put them in any order that you want them to start up in.
    I use it to put a delay on Yahoo Messenger, Skype and a few other programs that I do not need instantly when windows starts. It decreases the time it takes before you can start using the PC for sure.
    From their website:
    When Windows loads it's Startup file, it attempts to load every program in there at the same time. Therefore if you have quite a lot of programs starting when Windows starts, each program will try and grab CPU and Disk time so that it can load.
    If each program tries to do this at the same time, you soon notice the slow down that occurs due to your CPU trying to help all the programs to load, and your hard disk accessing multiple files.
    Startup Delayer allows you add some order to this process by determining the best time to launch your Applications. You can choose to do this based on how idle your computer is, or you can set an arbitrary time.
    My Fiero Build Thread
  3. #1333
    Jan 2009
    Quote Originally Posted by sikam32 View Post
    I just have installed DFX 5.1.0, but when i try to change a playlist, i choose the the play list i want and then nothing happens.
    The playlist is not changing and i still hear the previous songs. Is there a setting that i have to change???
    Ok, the problem solved. It was my windows set up. I used Win XP Micro. Now i am using Win XP Lite. All my problems R solved.
    Now i need your help about something else. I am using automatic adjustment day/night but when adjusting i am loosing my logo. Is there a way to avoid loosing logo during adjustment???
    And a last one. Is there a way to use Destinator 7 with DFX 5.1???
    Thanks in advance :-)
  4. #1334
    Nov 2009
    Quote Originally Posted by mitchjs View Post
    Mitch i am using may 2011. I think i need to upgrade. Shall I try that first? What version should i upgrade to? Most Recent?
  5. #1335
    MySQL Error
    Oct 2004
    well... how About what is resumemusic= in rr.ini?
    and of course you the most recent!!! 7/1 release! (i bet it is ok, in 7/1, remember sources got tweaked in april-june 2011)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #1336
    Nov 2009
    Mitch
    I updated to 7/1 but still the same problem with the list showing music instead of radio
    my rr.ini shows
    resumemusic=0
    Mike
  7. #1337
    MySQL Error
    Oct 2004
    change resumemusic=0 to 1
    resumemusic=1
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #1338
    Mar 2011
    Sydney, Australia, Australia
    Hi John,
    First of all, thanks for DFX5.1... I'm loving it.
    I'm setting up a Biometric scanner (finger print scanner) in the car to lock down the carputer, but also to be used as an immobilizer for the car (if RR is locked, you won't be able to kick start the car). My issue is that I cant find a way for the biometric software to enter the password in the skin. Maybe I need to send the password directly to the variable, not too sure. Would you have any suggestions?
    Thanks for your help,
    bebetaz
    PS: I just tried a few things and it don't seem to be able to send anything from the biometric software (Omnipass) to ride runner. I guess I might have to build a little .exe in vb6 then embed it in a skin, hopefully I'll be able to control the exe via omnipass. Will let you know how it goes.
  9. #1339
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by bebetaz View Post
    Hi John,
    bebetaz
    Not to hijack this thread and promote one of my own products, Ok maybe I am, have you had a look at Access Control?
  10. #1340
    Mar 2011
    Enforcer, smartass !!! hehe
    Thanks mate, trying it now...
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
