View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1341
    Mar 2011
    Sydney, Australia, Australia
    ok, this looks promising, but I am not too sure how it works.
    First thing, the setup, RR doesn't seem to be available, only Centrafuse and iDrive from what I can see. Second, when I setup the default password, save, and close the config screen, if I run AccessControl.exe, I can enter anypassword I want, even the right one and click submit, but nothing happens... what am I doing wrong?
  2. #1342
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    Not to hijack this thread and promote one of my own products, Ok maybe I am, have you had a look at Access Control?
    Actually DFX has password protection built into it. Just tap the top left corner of any of the main menu screens to access it. The default pass code for using the on screen keys is 1234. You can change it to whatever you want on the password screen.
    It will lockout the skin, even if rebooted. You can also press and HOLD the "Valet" button on the exit screen for the power options for when that button is pressed. You can set it, when the valet button is pressed to lock and shut down, lock and hibernate, or lock and standby.
    However, I am not sure how to access it with the omnipass software. It has been a long time since I have used it. Can you drag the omnipass cross hairs (Their new password field wizard) over the text field on the DFX lockout screen to set it to enter the code in the text area when you put your finger on the scanner?
    If it is a MS scanner, give Enforcers plugin a go for sure.
    My Fiero Build Thread
  3. #1343
    Mar 2011
    Hi John,
    so far I have been trying both, the builtin DFXLocker and Enforcer's Access Control, as well as a simple text and command button in vb6 and I can't seem to be able to get omnipass to enter recognize the password field. everytime I try it says:
    "You must select a valid field or button on the dialog you want the Omnipass password wizard to configure"
    the best result I got so far was with Access Control, I could get omnipass to enter the password in the configuration screen, but not in the actual access control screen...
    Will keep you posted...
    bebetaz
  4. #1344
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Hi John,
    I have my system working pretty well overall and enjoying your skin, but I have one thing that is bugging me and I was wondering if you could point me in the right direction.
    I usually listen to HD2 (sub channel 2) of my local radio station, but when I resume from hibernation it always goes to the main channel. I'm pretty sure that the command is being sent properly but because it takes the Visteon radio a while to lock on it ignores the HD2 command at the time it's sent.
    What would be the best way if possible to have a delayed command sent say about 30 seconds after RR resumes to send a sub channel 2 command? Preferably only if HD Radio is the currently selected audio source.
    Thanks for any suggestions!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  5. #1345
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    @zogg
    I will let Mitch chime in on this one, as it is not really skin related, and I honestly do not know if that is possible using skin commands.
  6. #1346
    Apr 2005
    Plano, TX
    Quote Originally Posted by JohnWPB View Post
    @zogg
    I've already checked with Mitch in another thread. There's really no solution with the radio itself because the computer and RR are ready way before the radio itself is.
    I was thinking in terms of the HD Radio skin. When the radio kicks in, I have to go to that skin and press the SUB 2 button. So whatever command is sent when I press that button, I want it sent automagically about 30 seconds after RR starts up.
    I know of a utility that can run a program or batch file upon system resume, and delay is no problem, so I could do something externally based on time if there is a way for RR to detect the event and act upon it.
    I guess I'm threadjacking, sorry. You are the master of RR scripting so I thought maybe you would know a way to do this.
  7. #1347
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by bebetaz View Post
    Probably best if you ask specific question in the AccessControl thread
    http://www.mp3car.com/other-cool-stu...rol-1-4-x.html
    rather than clutter up the DFX skin thread.
    The Centrafuse and iDrive are just images, you can create your own to fit in with whatever software you are using.
    If you want to use just one use make sure you don't out a passcode in for the multiusers as that will then take preference.
    I was merely suggesting AccessControl as it can work with some fingerprint scanners, specifically MS and bebetaz was asking about fingerprint scanner access.
    Also AccessControl has other features which DFXLocker does not, video & audio recording, access via a USB key to name a few.
    Hi John,
    bebetaz
    Having a quick look at the Omnipass manual it looks like it is looking for a textbox, AccessControls textbox is off the screen so it doesn't get clicked accidently. Which is fine for the MSFingerprint scanner, but maybe not for the omnipass.
    Looks like I will have to download the trial version of their software and give it a try.
  8. #1348
    MySQL Error
    Oct 2004
    Quote Originally Posted by Zogg View Post
    doesnt RR Extended have some timers?
    what i think you would want, is start a timer when "ONSKINSTART" happens and/or "ONRESUME"
    then when the timer expires, do the tune and hdsub commands
    like
    "ONTIMER1","RTUNE;93.3||HDSUB;2"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #1349
    Aug 2005
    Iceland
    Quote Originally Posted by Roadwarrior View Post
    I am going to do few experiments for the next days, when I have time. This might be connected to my sounddrivers (realtek) but I dont know. I will post a screen shot of the error as soon as possible.
    Is this file nessisary for DFX??
    Ok here down below is a screen shot off the error.
    I have since this screenshot was taken reinstalled Win7. I also installed, Winamp, RR July edition, and DFX5.1 and nothing else.
    The problem still exists.
    Any ideas and also is this file nesasery?
    I have now also tried to install on another computer with same results
    2005 VW Passat FSI 2.0
    Iceland
  10. #1350
    Apr 2005
    Plano, TX
    Quote Originally Posted by mitchjs View Post
    like
    Thanks, Mitch! I will play with this stuff and see if I can get it to work as I'd like.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
