View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1371
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by Enforcer View Post
    Replacing MSCOMCTL.OCX:
    SOLUTION:
    In order to fix this problem, you'll need to set up and register the library file.
    download the file you are missing and manually register it yourself. Here's how to do it:
    Download MSCOMCTL.OCX .
    Back up your current copy of MSCOMCTL.OCX and copy the new version to the same file location. This file should be located in the WINDOWS\SYSTEM directory on your C: drive (for Windows NT and 2000: \WINNT\system32).
    Using your mouse, click on the "Start" button and then click on "Run".
    According to your Operating System, type the following command to register this library file:
    Windows 95, 98, or Me:
    regsvr32 \windows\system\MSCOMCTL.OCX
    Windows NT or 2000:
    regsvr32 \WINNT\system32\MSCOMCTL.OCX
    Windows XP:
    regsvr32 \windows\system32\MSCOMCTL.OCX
    You should see a message saying "DllRegisterServer ... succeeded"
    If you are getting an error telling you that the file is missing, then you are not typing the command in correctly. You will need to type it in *exactly* as as shown above for your operating system.
    * Please note that there is a SPACE after "regsvr32" and before the rest of the command.
    You should probably copy and paste the command so that you are unable to mistype it.
    For win7 64bit users, <windir>\syswow64\MSCOMCTL.OCX
    It HAS to be there, as it has to run as a 32bit process. It will try to register as 64 in the system32, etc folders.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  2. #1372
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    today I noticed the color changer stop working?
  3. #1373
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Paul Murray View Post
    Thats kind of like taking a car to the shop, and saying "I noticed my does not run". A little more information would be quite helpful Skin version, patches installed, RR version, What operating system ect.
    I just tested the color chooser, and was able to change the background color, font color, and the progress bar colors with the latest RR version.
    My Fiero Build Thread
  4. #1374
    Jun 2011
    CINTI OH USA
    Quote Originally Posted by JohnWPB View Post
    Your right! I did post all that somewhere in this thread sorry
    I am on win 7 64 (thinking of going to XP) ASUS AT3IONT-I DELUXE 4gigs of Memory
    I down loaded DFX5.1, RR all at the same time about 3 weeks ago at the end of June,if that helps any?
    I notice that DFX installed in "my document" and not in the programs folder.?
    I get a com port error pop up
    color changer stopped working, also the program hangs every so often I think maybe due to winamp (even with direct sound) not sure? I just uninstalled winamp last night.
    I have tried others starting with a demo of Centrafuse hated it, lets see openmoble was OK
    but RR with your skin is pretty cool if I can get it rock steady..
    My next step is to maybe try it all over on XP, to think I was just going to buy a JVC and opt Car PC instead
    Thanks John for your time and reply.
  5. #1375
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    With Vista and newer, RR installs in whats is called "Profile" mode. Which in short, only installs the program files in the program folder, and any write to files(skins/config), in your my docs/RideRunner folder, to comply with OS requirements, eg UAC complaint.
    This is probably due to a XM/Sirrus/Radio port that was set but there is no HW attached. And usually the error message tells you for what it is having the problem open the port for.
    This could very well be the case, there have been some posts in either this thread or threads in the main RR forum that describe W7 and winamp hang-ups.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #1376
    Jun 2011
    CINTI OH USA
    Thanks!
    I think I read on here somewhere that you run XP.. is this correct?
    cos seems like win7 is a speed bump for this type of set.
  7. #1377
    MySQL Error
    Oct 2004
    no need to move BACKWARDS to XP....
    ALL XP or otherwise installations should be in PROFILE mode anyway...
    it(ref RR) was always violating the MS Rule of where data/programs should be stored...a ton
    of software other there is/was in violation too...because on down side in XP is everyone was an admin user
    and MS didnt enforce the rules where data should be stored... now since User Account Control
    from vista onward, they enforce it...now you can always turn UAC off, and prob should in the CAR PC(not desktops)
    just because, well i cant think of any real reason... other than id think in a CAR PC you're less likely to download/install
    malware...
    some patience and they will have a fixed DFX5 Installer...
    meanwhile you can fix it yourself, since your RR is in profile mode
    delete the rr.ini in program files/Ride Runner
    and then use the Legacy to profile mode program in the sticky
    and finally, when its done, reregister DFX5.dll which is in my documents/riderunne/skins/dfx5/plugins/dfx5
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #1378
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, I still run XP on all my comps, but heavliy thinking about updating my DT to W7. There are several users that are using RR/Winamp/W7 setups with no issues, matter of fact, Mitch's RR dev work/testing is done on W7 64 machine.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1379
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Blue, I'm going to upgrade to ...and only if..."DFXVoice" will work/support W7. That will be my only reason to upgrade from XP to W7.
    If it's not broken,...bla,bla,bla.....bla.
  10. #1380
    Jun 2011
    CINTI OH USA
    Thanks mitch I really didn't want to reformat,I DL'ed and Booked as said "RideRunner Profile Mode and You"
    I would like to used winamp I am all about the EQ cos I dont have that option to tweak every artist with WMP like I do with WINAMP in DFX
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
