View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 15 of 246 FirstFirst ... 567891011121314151617181920212223242565115 ... LastLast
Results 141 to 150 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #141
    Jul 2006
    Just another quick one, does the stopwatch work for anyone else?
  2. #142
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Kbreeden,
    Yes, Trader, SAPI is already installed. As I mentioned in my post, all works well if I start RRVoice listening manually. All worked well with the beta of 5.0 that I was testing, but not working with the released version.
    To All Again!
    The install of DFX 5 where RRVoice is concerned is not correct...
    RRVoice ini is in the wrong location...
    The RRVoice.ini in C:\Program Files\RideRunner\Skins\DFX5\Plugins\RRVoice
    Should not be there...
    It should be in C:\Program Files\RideRunner\Plugins\RRVoice
    Overwrite the RRVoice.ini that is there...
    You should only have Menu.ini in C:\Program Files\RideRunner\Skins\DFX5\Plugins\RRVoice
    ALso RRVoiceConfig.exe is not the correct version...
    The correct current version is 1.0.0.62...
    It can be found in the first post of the RRVoice Thread
    in the RRVoice.zip file posted...
    ...JJG
  3. #143
    Raw Wave
    Jun 2002
    Virginia
    Thank you, Jebus. I thought the last version of DFX5 was to fix this issue, but you have confirmed that it does not.
  4. #144
    Jul 2007
    Quote Originally Posted by trader007 View Post
    any quick fix to get the osk in garmin to not be opaque? or at least have a transparent background... the top background area blocks out the screen. you can still use the keyboard but you cant see what you are typing.
    Yes, I have this problem also. It does seem to be that the background needs to be transparent. If it can be changed, this is a big improvement to the OSK I was using before!
    Thanks for the new skin. As always, Donations will be on their way.
  5. #145
    Jul 2006
    Quote Originally Posted by Jebus View Post
    To All Again!
    ...JJG
    Also would I be correct in mentioning you need to edit the third line of the RRVoice.ini to point to your actual music path?
  6. #146
    Dec 2007
    Washington, USA
    Quote Originally Posted by andygardner View Post
    RRVoice does this for you on first run...
    ...JJG
  7. #147
    Dec 2008
    To All Again!
    ...JJG
    on this note, when i run the "create" command in rrvoiceconfig, it creates a menu.ini file in the C:\Program Files\RideRunner\Plugins\RRVoice path. the menu.ini file just contains these lines-
    [Settings]
    StripChar=-_[],.()!@#$%^*+><?
    PlayMusicCommand=LOADLIST;
    PlaySongCommand=PLAYITEM;
    PlayMusicXtra=
    PlaySongXtra=
    MusicCmdStatus=Command Sets Not Done
    is this normal?
  8. #148
    Jul 2006
    ...JJG
    I must've done something wrong. I moved RRvoice.ini from the DFX folder to RRvoice, ran Riderunner then tabbed out and ran RRvoiceconfig and it was still set to MusicPath=F:\MP3
  9. #149
    Dec 2007
    Washington, USA
    Trader007
    I just ran it and it does not,
    That was left over from a previous install,
    You can delete it...
    ...JJG
  10. #150
    Dec 2007
    Washington, USA
    I must've done something wrong. I moved menu.ini from the DFX folder to RRvoice, ran Riderunner then tabbed out and ran RRvoiceconfig and it was still set to MusicPath=F:\MP3
    REREAD the post about this...
    Nothing there says to move Menu.ini anywhere!
    You need to restart RideRunner after following the post properly...
    Then run RRvoiceConfig....
    ...JJG
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
