View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1541
    Newbie thinkfta's Avatar
    Jul 2009
    Seriously, I was just going to try that.
  2. #1542
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Unhappy
    I'm going to re-install DFX again, once it's in the app mart. I reverted back to my backup for now until things get iron out. As you can see I don't have fuel prices anymore, but it works in carwings and my DFX backup. And something is wrong with the button editor in the new DFX too, as you can see below. Oh well,.... what a shame I was really loving this updated version. Sorry guys.
    PS:If there is a skin update fix from within the DFX skin, I'll give it another go at it. I guess...
    Lucky this is on my test machine,.....and if I get everything working ship-shape on W7 OS,... XP should be a breeze,..right?
  3. #1543
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by RAWPWR View Post
    Ya, we are really hoping to use the updater to push out any/all updates. The installer will only be updated from time to time, as its a PITA to constantly re-upload it...
    I haven't touched that btn editor in quite some time now, I may need to revisit it. And I'll check out the Fuel prices not showing here.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #1544
    May 2007
    Cool, it's all good then....I'll just wait, not a problem.
    Yeah, that makes sense. That's what the updater is for,.... no more re-ups.
    Also, did you by any chance take a look at this other problem I'm encountering---> post#1534
    Thanks Blue.
  5. #1545
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Okay my wifi notification is not working even though I am connected, and the updater is not showing anything on the page at all. I also did a search for the dfx.dll and did not find it anywhere on my hard drive. Along with the Cover Art Browser not working. Any relation between them all.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  6. #1546
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That would be cause of what you searched for....DFX5.dll
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #1547
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes you do, see its right there...just labeled differently Gas Prices = Fuel Prices
    Yes, I do see that its broken.. I'll look and see what we caused it to brake.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #1548
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Ravenhawk View Post
    I was trying to get this to work but I must be missing something. Every time I hit the Maintenance menu button I get an error that says the No Language File Present. Any idea how to get this working?
    Recent version of RRVM? I just downloaded...on a fresh install here and did have an issue, not related to yours though...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1549
    May 2007
    Blue, FuelPrices all fixed now. Take a look at the skin.ini file.
    I had a problem with #20 and #22.
    They were set for Gas Prices.....Load; Gas Prices skin. etc.
    So I made the change to RRFP and all well.
    Also, there is no FuelPrices.png in the menuIcons folder, so I copied the gas one and renamed to FuelPrices.
    Yes, button editor would have made things easy.
  10. #1550
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    Its the Plugin called GPSLockout that is one of the very few that are included in the installer now. It uses the SPD from the gps data from RR, so if wonders a bit while stationary and shows you going faster then the lockout set speed it will...er..lock you out of video/dvd type features. You can either disable/uninstall the plugin, or you can set the lockout speed setting up a bit higher to prevent such an issue. Easiest way to disable it, would be to unregister the dll found in the RR\Plugins folder, or if you want to simply keep it and try adjusting the setting via the ini also found in its plugin folder. Speed is the name of the setting, and I believe that the default on that is 3mph
    Thanks once more! NAILED IT.
    Now there is this issue the menu does not hide while watching videos,is there config for this?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
