Originally Posted by
Blue ZX3
Sounds like its getting caught up when its trying to create the btn list, as it does everytime you P&H a menu btn to keep the listing always current. Turn on RR's debug, in the skin.ini under the MISC section, set the DFXDebug=True. Then start up rr and give it a try, attach both your rr debug and the debug.txt found in the dfx5\plugins\dfx5 folder.
Ya, the help file is to say the least, a bit out of date.... along with the above debug logs when you go into that screen, the btn should say "Check for updates", clicking it of course should do as it says. Also see if after you do that, you have a "DFXUpdater_debug.txt" file in your dfx5\plugins\dfx\autoupdater folder, if so, attach with the other above files...
