View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 16 of 246 FirstFirst ... 6789101112131415161718192021222324252666116 ... LastLast
Results 151 to 160 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #151
    Jul 2006
    I'm just testing voice now and for some reason when I 'push to talk' the audio playback isn't being muted?
    edit: typo before I mean't RRvoice.ini I did follow the post properly didn't I?
  2. #152
    Oct 2010
    Quote Originally Posted by andygardner View Post
    DFX becomes unresponsive when I open the gauges screen and it's receiving data from the GPS device. If I go to the gauges screen without the GPS enabled its fine.
    I'm using xport 1.43; GPS device is on COM3 and ouput is on COM8 and COM9. In RRconfig on the GPS screen in the 'Other' section I've 'GPS Port:' set to 8
    As soon as you open the gauges screen you're screwed. It shows positive lock on sattelites and elevation info but all the buttons cease functioning leaving you stuck on the screen.
    Hi. First of all thanx for this great Skin!!!!!
    Second, I have this same issue.
    Rgds John Kay
  3. #153
    Raw Wave
    Jun 2002
    Virginia
    Next issue; the accuracy of speech recognition.
    Has nobody else had problems getting it to actually work as intended? And this is in reference to SAPI not RRvoice, from what I tell RRvoice is doing everything it should.
    I've trained four or five profiles from scratch now and it's just absolutely useless. I literally can't get it to recognise the word 'artist' the only useful word I can get to work consistently is 'menu'. And this is with the best queens english.
    I must be doing something wrong but god knows what! It's driving me up the wall.
    Andy, make sure that the commands you are issuing are actually available to RRVoice. If not, the commands won't be recognized. Click on the little RRVoice mic at the right side of taskbar and then click Show RRVoice. This will bring up a window showing commands that can be recognized. It may be that the command isn't available to you rather than a problem with speech recognition. If that turns out to be the case you can then try to figure out why the commands aren't there. I just experienced this. I don't know why the commands that were supposed to be there, weren't, but I was able to sort it out somehow.
  4. #154
    Jul 2006
    Quote Originally Posted by kbreeden View Post
    I actually did just this, very useful for seeing what's going on/what's being recognised etc. As I said RRvoice seems to be doing everything it should be (except muting audio which it was with DFX 5.0.1?), I actually just got it to 'play artist' a few minutes ago but it was a serious fluke.
    Bundled with the SAPI5 SDK there was a little vb program called dictpad which I've been using to test recognition and it's clear that something is very wrong either; with the way I'm training it or as you suggested the microphone.
    I've succumbed and ordered the Andrea mic, so that should narrow things down when it arrives.
  5. #155
    Dec 2008
    Quote Originally Posted by Jebus View Post
    Trader007
    I just ran it and it does not,
    That was left over from a previous install,
    You can delete it...
    ...JJG
    ok thanks. i finally got things working right again! i had problems with my rrvoice.ini file too. i tried a few things and suddenly i got results i wanted. not sure what i did honestly though. for whatever reason, my stuff isnt doing the same things as what the instructions say should happen.
    anyway, it seems to be working really well now. just need to change some commands around to work with what i have. i am able to say the artist, then say the album, and say "next song" when i want to. thats about all i was looking for! now to just comb through my music collection and rename the file structure for better accuracy.
  6. #156
    Dec 2008
    I must've done something wrong. I moved RRvoice.ini from the DFX folder to RRvoice, ran Riderunner then tabbed out and ran RRvoiceconfig and it was still set to MusicPath=F:\MP3
    yes you are following things correctly. just set the music path manually. it never changed to the right path for me either, i just do it myself and make sure you hit "set value" in the botton right corner to lock in the setting (using rrvoiceconfig.exe)
    also, after you set your music path and run the "create" command, post what you have in your rrvoice.ini file. i have a feeling you might be experiencing the same problem i was....
  7. #157
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Remember, If you change your music structure in any way, You must run RRVoiceConfig.exe to scan your music again...
    You must also do this with RMDatabase, I believe...
    ...JJG
  8. #158
    Dec 2008
    actually i think rmdatabase does it on the fly. ive been impressed by how fast you see music in your browser list after you add it to your music folder, it can be instantaneous at times. not sure how well it catches subtle changes though (like renaming folders... even though i go by id3 tags anyway for the browser)
  9. #159
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Mobile Phone?
    Quote Originally Posted by mnwcsult View Post
    I am looking for the mobile phone screen setup. What do I need.
    Anyone care to chime in one mobile setup or plugin. Way back JohnWB show a screen in the future DFX that had a mobile phone connected.
    I always really wanted that.
  10. #160
    Dec 2008
    im not sure if john ever got that itegrated with dfx5 or not. the skype plugin does work great though, i am pretty much shocked how easy it was to setup and how well it works. i havent figured out the voice commands yet though.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
