View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1611
    Jan 2011
    Everett, Washington
    Blue,
    That's what I thought it might be and tried to change that by holding/touching that section, setting the opaque to 255 and have even toggled it on and off. I am using the new beta config program to make those changes.
    Brian
  2. #1612
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Attaching a pic might give better idea, but i still am thinking along visu..IDK
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #1613
    Jun 2007
    I recently updated DFX to the latest version. However there are many buttons that do nothing when selected. I have gone through everything and cant figure out what the issue is.
    The following buttons do nothing when selected:
    EQ - is turned on in winamp
    Browser - in music tab
    Build Music Database - folders are properly formatted
    Color Theme - will not change colors
    Change Colors - will not change colors
    Global Settings - the one in the theme/logo menu
    Pictures Path - wont allow selection of pictures folder
    also not working but not too worried about;
    Enhanced Internet Radio Labels
    New Mixer Sliders
    Pop-up Greeting at Start-Up
    Also none of my album art shows up. I have album art for nearly every song I have and it loads on other devices. Not sure why none of it loads in DFX.
    Id appreciate any help you can offer =)
  4. #1614
    Jan 2011
    Everett, Washington
    Blue,
    You know this much better than I ever will and I have to agree with you but I am dealing with a different issue with the puter (not seeing the 2nd drive) but what should the visual be set to? Should it be checked or unchecked? I don't want any visual display going on other than the test of what I have plating at that moment. Also if it's checked or not checked should it be set to 255 for not being able to see any special visuals or not?
    Tia
    Brian
  5. #1615
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    Yeah DFX is certainly the hot rod of front ends..! I've got mine looking sweeet.
    Now if I can just get this SUMA mic to work over the moblephone plug-in I'll be all set,till then Ive got to run CF cos everything is working in there
  6. #1616
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Anyone know how to setup-use the clean screen (with the dog) with RRVOICE?
    What needs to be put in the RRVOICE.ini file?
    I want to show off that I can clean the screen with only my voice. LOL
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  7. #1617
    Mar 2008
    WPB, FL
    Still no resume last position on disk changer ... bummer ... guess I'll just have to give up on DFX5
    VIA EPIA-MII12000 • M2-ATX 160W DC-DC • WinXP Pro SP3 • 1 Gb Mem • 250GB HD • Xenarc MDT-X7000 • BU-353 Weather-proof GPS Receiver • iGuidance • D-Link DWA-130 • RideRunner (08/11) • DFX4/DFX5.1
  8. #1618
    Aug 2005
    Iceland
    I have been trying to use the "DUN" button. I have installed SPdialer and have told the program what key to use and also I had a look in the connect.vbs file. I have changed keys in both places but it does not work. Any ideas?
    2005 VW Passat FSI 2.0
    Iceland
  9. #1619
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by michaelrj9 View Post
    Ya, just add: Clean the screen=ScreenClean to your rrvoice.ini in the global section
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #1620
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Exclamation NOTE TO ALL DFX5 users
    Important Notice!
    For anyone updating to the 09-01-2011 RideRunner or newer versions, please see post#2 BEFORE running RR/DFX5 after updating.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
