View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1631
    Jul 2011
    Quote Originally Posted by JohnWPB View Post
    Not really anything to edit inside DFX or in RR for the mic really. I would check your BT settings and or windows sound recorder and make sure they are set to use the Andrea mic, and not the on board mic that is usually set by default.
    Thanks I will have a look at the BT settings
  2. #1632
    May 2011
    John and Blue, just letting you know that for some reason, per the latest update instructions regarding RR (9-1) and DFX 5.1.1, that the exectbl.ini (for me anyway) didn't update using the DFX Update function. Was able to fix the "Exit Loop" problem by editing the .ini manually per the instructions in post #2.
    This was a fresh install of both RR and DFX. Installed RR, then DFX 5.1.1, then the DFX 5.1.1 Loader and Donation patch. Ran RR after the Donation patch and then ran the updater in DFX. Got caught in the loop on the RR restart after the updates were applied. Killed RR with taskman. Restarted RR, Closed RR, hit the loop again. Afterwards, manually edited the .ini. All ok now.
  3. #1633
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    What line will I need to edit to get Garmin to pulse winamp as IG does?
    Much obliged
  4. #1634
    Apr 2011
    John, Blue any ideas on post #1621.
  5. #1635
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Paul Murray View Post
    What line will I need to edit to get Garmin to pulse winamp as IG does?Much obliged
    There isn't a line/setting that can be changed for easy setup of that when using garmin b/c RR has built in code to deal with IG and controlling the player volume.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #1636
    Jun 2011
    CINTI OH USA
    oh foo-wee well,thanks for the info Blue. I am looking at something called nav mute I know I am late in the game but its all new to me...
  7. #1637
    Jun 2011
    CINTI OH USA
    OK Here is what is going on now, I got the moblephone.net plug in to where i can make calls & they can hear me out of DFX,ONLY when someone tries to call me the caller ID BOX flashes music pauses DFX skin freezes/locksup and I can't answer the in-coming call.. then when the caller hangs up,it frees up the skin..
    any ideas on what could be causing this?
  8. #1638
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    attach a debug log is about the only thing that i can suggest.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1639
    Jun 2011
    CINTI OH USA
    will do
  10. #1640
    Jun 2011
    CINTI OH USA
    here is my RR debug file..
    Attached Files Attached Files
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
