View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1671
    May 2011
    After finding out the hard way myself, if you didn't install RR in profile mode, you'll run into problems under Win 7. If that's the case for you, uninstall everything and then re-install RR with profile mode checked.
  2. #1672
    Oct 2010
    Hello. Thanx for the tip, but no luck. Must be something else.
    I have realised it has nothing to do with DFX 5.1.1 as I have uninstalled averything and with a clean install of RR usin Carwings I have the same problem.
    I will research the forum with a different view... concentrating on RR instead of DFX.
    Thanx and rgds
    pd.
    ok, I have re-installed the hole lot.... Win7, RR, DFX, Flash, etc etc and all working.......... It was some kind of problem with win7.......
    Thanx
  3. #1673
    Jul 2006
    I've done something very stupid, I tried to update to the latest version of DFX and Riderunner! haha
    My problem is DFX crashing/hanging when I press the music button. Here's a rundown of what I've done so far;
    Fresh install with win7 x86
    Chipset drivers etc
    Windows update
    Directx
    Flash 10
    Winamp
    RR 09/01/2011
    DFX 5.1.1 and donation patch (reboot)
    fixed the lines in exectbl.ini for the closing bug
    Start RR, click the music button and... nothing.
    What have I missed?
    Scratch that it hangs when I press any button. I've uninstalled DFX and RR/delete folders/reboot and reinstalled same problem. These two programs are the bane of my existence! Suppose I'll format the PC and try again.
  4. #1674
    May 2011
    Is the audio on your pc working ok regardless of RR and DFX? Looked like something was hanging when it came to the audio player section in your debug. Might be related to something not working correctly either with your audio drivers or winamp output settings.
  5. #1675
    May 2007
    Duarte, CA
    I had the same problem. chalked it down to the latest winamp not working properly. i used WMP as the media player, and problem went away. Then i installed a not so new winamp, and problem still was gone. i could have went the wrong way about fixing it, but its working fine now. hope that helps
  6. #1676
    Oct 2010
    Hello.
    Guess you have the correct paths for music and playlists right?
    Rgds
    JOhn KAy
  7. #1677
    Jul 2006
    Okay it just flat out doesn't work so I must be missing something fairly major. It hangs immediately on clicking any button.
    I've done two full fresh installs now. After installing windows (7 ultimate x86) and going through windows update I'm; updating dirextx, installing flash (through IE), installing winamp (setting skin to classic) then installing riderunner and dfx.
    Am I missing something like .net? Though I think that's included in windows 7?
    I'm going to try downloading RR and DFX again maybe they are corrupt? Any input would be greatly appreciated as this is ******* driving me nuts!
  8. #1678
    Jul 2006
    Quote Originally Posted by 4puteruser View Post
    Ding ding, we have a winner. I just switched to WMP and it isn't hanging, the problem is with Winamp.
    Are there any advantages to using winamp over WMP?
  9. #1679
    May 2011
    Cool beans! Glad you got it figured out. Now if I could just get S&T to actually embed I'd be getting somewhere .
  10. #1680
    May 2007
    Duarte, CA
    i didnt notice resume on sleep/hibernate working, mp3 info on MAIN page not displaying at all, or volume via steering wheel controls working properly with WMP (this could be fixed). Try downloading an older version of winamp, that fixed the problem. i always liked winamp vs WMP. Now all i am waiting on is DFXVoice and figuring out a way to use the Wireless app to connect/disconnect from actual networks. for me it ONLY disconnects the wireless card
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
