View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1681
    Mar 2008
    WPB, FL
    Speed volume has to be enabled at each start of DFX5???
    (that's been my experience.)
    FWIW, I liked the settings in RRConfig ...
    VIA EPIA-MII12000 • M2-ATX 160W DC-DC • WinXP Pro SP3 • 1 Gb Mem • 250GB HD • Xenarc MDT-X7000 • BU-353 Weather-proof GPS Receiver • iGuidance • D-Link DWA-130 • RideRunner (08/11) • DFX4/DFX5.1
  2. #1682
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Shouldn't... DFX5.0 did have the main settings in the skin.ini which would overide the rr.ini ones, but latter we decieded that it would be best to leave whatever they were set at in the rr.ini, so we removed those main ones from the skin.ini.
    Check your skin.ini for speedatt=x and delete if found. Also check the skins exectbl.ini, b/c if you use the speedatt screen in the skin, it will save it back to the skin.ini. Look for and change "SAVETOSKIN;speedatt;" to "SAVETOINI;speedatt;"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #1683
    Jul 2006
    Quote Originally Posted by 4puteruser View Post
    i didnt notice resume on sleep/hibernate working, mp3 info on MAIN page not displaying at all
    Yes noticed this problem today, mp3 info doesn't display on startup until i press the 'music' button, also no resume.
    Which version of winamp did you get working? I tried 5.35 (2007!) and still had the same problem.
  4. #1684
    Newbie LeonGR's Avatar
    Nov 2008
    Piraeus - Greece
    Quote Originally Posted by JohnWPB View Post
    Has anyone been using the Automatic Updater in the skin? I have put a few updates and bug fixes in there..... Is it working ok? The last update was a fix to the 4 day forecast weather screens. I moved things around a bit, and made the temperature's for the individual days larger.
    When someone gets a chance, update, and let me know if it all worked ok. Thanks!
    I have use the automatic updater and it is working fine.
    The problem that i have has to do with the hourly forecast, i am from greece and the units here are celsius and the symbol is °.
    I have managed to change the settings and can see the weather like it should be in Current weather and the 4 day forecast but at the hourly forecast i can't change the units and the symbol is not correct. It should say 25° but now it says 72'Ι for example.
    Sorry for my bad english and i hope that you can understand what i am saying
    Thanks in advance.
  5. #1685
    May 2007
    Duarte, CA
    Winamp 5.531 (8.57 MB) or
    Winamp 5.541 (5.09 MB)
    DFX auto updater worked good for me to do . man i wish i could skin. any chance of making the video skin have semi-transparent buttons?
  6. #1686
    Low Bitrate SoloconDeus's Avatar
    Sep 2007
    Garmin Mobile PC bug and fix 5.1.1
    Found a bit of a bug in the Skin.ini file. The Gamin entry looks like this in the code lines respective places
    Code:
    MenuExec_48=LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\ProgramFiles\GarminMobilePC\Que.exe;!CDP_FIELD_WND
    MainMenuExec_05=LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\ProgramFiles\GarminMobilePC\Que.exe;!CDP_FIELD_WND
    MainMenuLabl_05=Garmin
    I changed it to this in the code lines respective places minus the /---------------------------/
    Code:
    MenuExec_48=LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\ProgramFiles\Garmin\GarminMobilePC\Que.exe;!CDP_FIELD_WND
    MainMenuExec_05=LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\ProgramFiles\Garmin\GarminMobilePC\Que.exe;!CDP_FIELD_WND
    Then Garmin Mobile PC would load. The only issue is that when I go to Exit RideRunner it hangs because Garmin Mobile PC will not close. Has Anyone got an idea how I can get Garmin to exit on close, the code forthat is eluding me.
    My new install
    D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
    Visteon HD radio w/mitches cable, BU-353
    2 Punch 150 amps, 1 Kicker ZX 400.1 watt
    4 Boston Acoustic Speakers,2 Pioneer 10 subs
  7. #1687
    MySQL Error
    Oct 2004
    Quote Originally Posted by LeonGR View Post
    Thanks in advance.
    im not 100% sure, cause u mention it changed in current... but...check...
    welcome to the world of unicode and using ansi .ini files to store settings
    you have to get the right symbol in where it is saved
    skin.ini
    edit with notepad
    i would save as ansi file
    since you should be in greece codepage
    weatherdegrees=º
    good luck
    there is a perfect solution, we dont use .ini files anymore
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #1688
    MySQL Error
    Oct 2004
    Quote Originally Posted by SoloconDeus View Post
    Code:
    Code:
    im not 100% sure, but you have to tell rr this is an embedded window
    in rrconfig, embedded apps
    and then close on exit should work
    if that option is taken
    (as you can see for me since im using iguiance as nav)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1689
    Jun 2002
    Virginia
    Finally got around to downloading 5.1.1 for the carputer. Automatic update works great. Very sweet.
    Only problem is that I can't disable the registration screen even though I'm a registered user. I installed the skin and then did the update and the registration screen disappeared. Shortly thereafter, it appeared again and I can't get rid of it. I know I can't use the old patch. Any solutions?
    Also, is there any way to do custom buttons with this version? I used to use the DFX button editor included with the skin to customize a few buttons, but am now getting an autoit array variable error when I try to launch it.
  10. #1690
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya the dfx btn editor is broken and seeing as not being anything high priority, is on the back burnner for the moment. Been doing some rework on dfxvoice so that it can be released!
    Not sure on the winamp issues, current is now always recommend, though have tried any of the latest ones with RR.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
