View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1691
    Jun 2002
    Virginia
    Thanks for the confirmation on the button editor, Blue. No big deal because buttons aren't that important in the age of RRVoice.
    How about the registration screen problem? I figured I'd just thank you guys by buying the patch again, but the app store wouldn't accept any forms of payment. So now I'm stuck with the screen and the delay with no way to fix it. Any help would be appreciated.
  2. #1692
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by kbreeden View Post
    How about the registration screen problem?.
    You have a PM
    My Fiero Build Thread
  3. #1693
    Constant Bitrate overlander's Avatar
    Feb 2008
    As mentioned in earlier posting, I was having an issue with the updater doing nothing when I pressed the button on my 5.1.1 installation. I uninstalled it today and then tried the updater and it worked perfectly. I then applied my patch I bought last year (I think) and after rebooting RR, the splash screen went back to the 5.0 screen, and the updater page looked different and wouldn't work again. Definitely something to do with the patch. Did I miss something in an earlier thread about this?
    UPDATE: OK, I found the thread that showed the new patch so let's ignore my question. Recommend that patch fact gets updated in the FAQ.
  4. #1694
    Mar 2008
    WPB, FL
    Shouldn't... DFX5.0 did have the main settings in the skin.ini which would overide the rr.ini ones, but latter we decieded that it would be best to leave whatever they were set at in the rr.ini, so we removed those main ones from the skin.ini.
    Check your skin.ini for speedatt=x and delete if found. Also check the skins exectbl.ini, b/c if you use the speedatt screen in the skin, it will save it back to the skin.ini. Look for and change "SAVETOSKIN;speedatt;" to "SAVETOINI;speedatt;"
    Thanks ... applied your suggestions .... no change ...
    HOWEVER, changing SpeedAtt= & SpeedAttMute= from FALSE to TRUE in Skin.ini worked (why weren't these settings saved by the program?)
    NOW, if we also can find a fix for the no resume problem in CD Changer ...
    VIA EPIA-MII12000 • M2-ATX 160W DC-DC • WinXP Pro SP3 • 1 Gb Mem • 250GB HD • Xenarc MDT-X7000 • BU-353 Weather-proof GPS Receiver • iGuidance • D-Link DWA-130 • RideRunner (08/11) • DFX4/DFX5.1
  5. #1695
    Jun 2011
    Dublin, Ireland
    I'm having terrible problems with weather in the latest release and I don't just mean it rains everyday!
    On my xp box, RR hangs on the DFX screen when loading weather and on my Windows 7 box it locks up RR when weather is clicked. Other than that, I'm loving the release, especially the auto updater!
    I'm running sept version of RR and the latest and greatest version of DFX.
    P.s, Blue if you need a beta tester for dfxvoice, give me a shout! Can't wait to get my hands on it!
  6. #1696
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Well. as the forums have been a bit slow, I will give you a bit of the inside to DFXVoice while the coding is being completed to keep things rolling.....
    It will work very similar to RRVoice and does everything that that is capable of (all of the default DFX commands that worked with RRVoice have been ported over to DFXVoice). There is a lot of new stuff, and huge speed improvements on top of that.
    Blue put an ingenious bit of code in place, to play any song or album directly. It works along the lines of:
    To play any song in your collection, you follow this syntax:
    (you pause for a brief moment between the artist's name, and the song title)
    "Direct play Adelle" <Beep> "Song Rolling in the deep".
    To play an artist's album, this is the syntax:
    "Direct Play Madonna" <beep> "The immaculate collection"
    You can still play every single song by any artist with this command:
    "Play artist AC DC"
    I have around 45,000 songs in my Music collection.... I know a lot..... With DFXVoice I can think of any song or album in my collection, and have it playing in around 3-4 seconds of thinking of it!
  7. #1697
    Jun 2011
    Dublin, Ireland
    Sounds excellent!
    Do you reckon it'll be released this side of Christmas or is there a lot of work left to do?
    Perhaps a thread in the development section could be opened to keep us posted, it might increse the traffic through there!
    Keep up the good work!
  8. #1698
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, I have already started to do a Post#1 write up for DFXVoice.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #1699
    Jun 2002
    Virginia
    DFXVoice sounds great, guys. I'm curious whether we'll have to manually build an index of artist/songs/albums like with RRVoice.
  10. #1700
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, that part remains the same exept that will be able to be done in skin and in background, possibly after a rrmedia scan is done. And will use tags instead of file names.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
