View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1731
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    John, OK,.....now this just occurred. mmph! .......how do I fix this?
  2. #1732
  3. #1733
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Yes, E is correct. That particular font does not have the degree's ( ) symbol.
    You can try to change that symbol to something else in the RR.ini. Look for this line:
    weatherdegrees=
    And change the symbol to something else possibly.
    As one other option, you can change the font that is used to display the temperature numbers in the skin file. That way you can still use that font throughout the rest of the skin.
    By the way, I like that font, what is the name of it?
    My Fiero Build Thread
  4. #1734
    May 2007
    Quote Originally Posted by JohnWPB View Post
    weatherdegrees= And change the symbol to something else possibly.
    I gave it a go,....did nothing.
    I did this also,.....a no go.
    E, this is a real head scratcer? The character map clearly shows different???
    Why doesn't the degree symbol show? I'm stumped.
    Thanks, I like it too. It's called ("a_BosaNovaCps" version: 01.03). There's a bold version too which looks nice also. I'm still going to use it, and put up with symbol not showing up right in weather.
    Oh well, .....Thanks anyway gentlemen.
  5. #1735
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RAWPWR View Post
    Not quite, if you look at the character map (NB Win 7 here) and arial font, the symbol that looks like the degree symbol is actually called Masculine Ordinal Indicator and is character code ALT+0186, whereas your degree character code is ALT+0176
    There I suggest what you do is what John said with the weatherdegrees but after he equals sign hold down the ALT key and then n the numeric keypad type 0176
    weatherdegress=
    Here is my ALT+0176 and my ALT+0186
  6. #1736
    May 2007
    Thumbs up
    E, All fixed now my friend! Thanks a bunch.
    Now the question is why was the wrong symbol in the rr.ini in the first place???
    Quite a mystery eh.
  7. #1737
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    It's not that the symbol was in the wrong place in the rr.ini, it is probably a matter that when they made the custom font they put that symbol in the wrong spot.
  8. #1738
    May 2007
    Oh, I understand now,...thanks John.
  9. #1739
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Actually I disagree.
    ALT0176 is the correct code for the degree symbol, what is probably in the rr.ini is code ALT0186 which is Masculine Ordinal Indicator and whoever first put the code in the RR.ini probably picked the first degree looking symbol they found in the font they had, and got the wrong one.
  10. #1740
    Oct 2007
    Yea, when the system runs out of space, any files being written to can many times become corrupted, or emptied of their contents. This is a hardware / windows problem and is not a DFX, or any other skins problem. I have thought about making backups of the skin.ini, and will probably include this with the next release. It will just make a copy of it as a backup when the skin starts, and will be there if ever needed.
    Did you manage to implement this?
    Im running the latests skin updates but ran out of space again and the skin lost its settings. Looking around the skin folder but cant find a "last known good" settings backup.
    Only found skin(orig).ini and using that sets DFx back to defaults. Theres a zip file in !SkinUpdates/backup but doesnt contain a skin.ini file
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
