Route within Streets & Trips
Quote:
Originally Posted by
Driven01
Ok, the very last thing and I'll leave ya alone. Really. Ran into an oddity and am hoping one of you guys has an answer. I have everything running in the StreetsTrips.skin as it should with S&T 2011 under Win 7. All of the buttons are working and RR doesn't load a 2nd instance when changing from one screen and back again. Here's the odd part...
When S&T loads up, it loads with an empty route. If I create a route within the embedded screen all is well. Everything works as it should.
If I choose a pre-arranged route from the file menu within the embedded screen and then hit any of the buttons, RR Loses focus on the embedded window and then nothing works right after that. If I leave the Streets screen and then hit the button to go back to it, RR launches a new instance of S&T. It's like I'm back at square one if I use a pre-arranged route. Weird huh? Ideas anyone?
The problem is the way streets & trips labels the screen. The 'normal' name is Map - ... When you create a route, it has the name route name - ...
To get around this, I create the route and save it. Create a folder with the same name and copy the route into it. I then rename it 'Map'. Unfortunately, this doesn't work on the carputer itself. I usually create my routes on a separate computer and then load them onto my carputer.
This is a limit of streets and trips and not the carputer idea.
dnr
1 Attachment(s)
DFX Weather Settings screen
Continuing work on making all the major RR settings, available to set in the skin without editing ini's and such.
Here is the new weather settings page:
(The "set 4" icons are the animated flash ones)
