@steven
Yes, but be sure you install Riderunner in Profile mode under Win7.
The problem is the way streets & trips labels the screen. The 'normal' name is Map - ... When you create a route, it has the name route name - ...
To get around this, I create the route and save it. Create a folder with the same name and copy the route into it. I then rename it 'Map'. Unfortunately, this doesn't work on the carputer itself. I usually create my routes on a separate computer and then load them onto my carputer.
This is a limit of streets and trips and not the carputer idea.
dnr
@steven
@dnr250 - Thanks, but I got it figured out. S&T 2011 will now embed ANY Route I choose (or create on the fly) without issue. It mostly had to do with what information RR looks for to identify the embedded application window. Sometimes too much info can be a bad thing.
See post 1721. There are clues in there.
The same issue exists for ALL versions of S&T as well as other apps from time to time.
Continuing work on making all the major RR settings, available to set in the skin without editing ini's and such.
Here is the new weather settings page:
(The "set 4" icons are the animated flash ones)
My Fiero Build Thread
Very nice screen John :-)
So this error is only unique to me??
I can not answer in coming calls while driving as seen in the video the phone buttons flashes on and off screen and only appear after the caller hangs up!![]()
64bit for surely doesn't belong in a carpc anyway, whether it be XP/7..
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
