View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 18 of 246 FirstFirst ... 891011121314151617181920212223242526272868118 ... LastLast
Results 171 to 180 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #171
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Jebus View Post
    To All Again!
    The install of DFX 5 where RRVoice is concerned is not correct...
    RRVoice ini is in the wrong location...
    The RRVoice.ini in C:\Program Files\RideRunner\Skins\DFX5\Plugins\RRVoice
    Should not be there...
    ...JJG
    Yes, I have just checked this with a clean install of both RR Oct and the DFX 5.0.3 installer and did find that there was this error....Now corrected!!
    You should only have Menu.ini in C:\Program Files\RideRunner\Skins\DFX5\Plugins\RRVoice
    ...JJG
    Again, after the above checking, this has been fixed. The installer will be updated soon to reflect these missed items.....Now corrected!!
    ALso RRVoiceConfig.exe is not the correct version...
    The correct current version is 1.0.0.62...
    ...JJG
    Using the above checks, I will confirm that it installed the correct version on a clean install, but might not overwrite if trying to install over existing older RRVC files.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #172
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by andygardner View Post
    Clearly I'm an idiot for not immediately realising (US only) meant it would break the gauges if you're outside the US.
    This is not actually skin related per-say...it is a built in RR feature, that uses this file for retrieving US state, city and zip info. To which can be used in several different ways in a skin depending on how the skin authors put it to use.
    Now what I could do, is maybe make it unchecked by default and if user wants to install the file, notify the user that this will only work in the US, just as an extra precaution.
    [EDIT]
    And now after checking when going to the the gauges screen, it does call the RR cmd "LOCATE" which tell RR to reupdate the location labels at the top of this screen, using the zips.dat file. That is where you were having your issues...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  3. #173
    Raw Wave
    Jun 2002
    Virginia
    Just another quick one, does the stopwatch work for anyone else?
    Stopwatch does not work on either of my two machines using RR10/04/10, DFX5.03 and XPSP3. The screen comes up as it should, but it does not count the time properly. When I hit start the tenths of seconds count up very slowly, an increase of about one tenth of second per minute. It did work on the beta versions with the September RR, but I don't think I've used it with any of the DFX release versions.
  4. #174
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Mobile phone skin
    Quote Originally Posted by ccwild View Post
    It works for me.
    What I should probably asked is where I should be looking in order tho have the mobile phone show on the menu.
  5. #175
    Mar 2007
    Maryland, USA
    DFXSpeak error
    I am getting a popup from DFXSpeak, cannot create object. Any ideas?
  6. #176
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I shouldn't really be answering this question......but press and hold the button where you want it to be and select it from the list...
  7. #177
    Mar 2008
    WPB, FL
    Quote Originally Posted by Rev1979 View Post
    Any answers yet to post 256 in the first DFX5 thread?
    http://www.mp3car.com/vbulletin/rr-r...ml#post1415137
    Quote Originally Posted by JohnWPB View Post
    Sorry, no clue why it would be doing that. The RRMedia plugin saves the song and position for the disk when switching, and it does work here correctly.
    Can someone else post if when changing virtual disks if it remembers the last song and position it was playing when switching to a disk?
    Anyone?
    I don't have RRVoice installed (or speech sdk), could that be an issue? I noticed post 157 mentioned a connection between music structure and RRVoiceConfig. Just grasping at straws here...
    [This may not matter to most users, but I listen to a lot of books, I switch to music when I have folks in the car and then back to my book when alone. Having to relocate a track in DFX5 among 900+ tracks on a book means I'll have to stay with DFX4 ... and that just sucks because of all the cool stuff in DFX5!]
    Thanks for your help.
    VIA EPIA-MII12000 M2-ATX 160W DC-DC WinXP Pro SP3 1 Gb Mem 250GB HD Xenarc MDT-X7000 BU-353 Weather-proof GPS Receiver iGuidance D-Link DWA-130 RideRunner (08/11) DFX4/DFX5.1
  8. #178
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    agree mmmm helpfile mmmmmm
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #179
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Why, you running out of spoons?
  10. #180
    Mar 2007
    Maryland, USA
    I thank you for the spoon feeding
    And yes deep down I knew that to be the answer. However really working way too many things and without thinking I asked a "user" question.
    And to Enforcer, thankfully Blue had not run out of spoons.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
