View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1801
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    RRCalendar is still in Beta. Sonic has not finished it yet, and I had just started to get it incorporated into the skin.
    Ok, something new
    The Weather Channel decided to stop offering the free weather feed that RideRunner uses for weather information. Guino spent conciderable time on creating a new plugin, that will be available soon. It uses WeatherUnderground's free feeds. Nothing has changed as far as labels and such in the skin. So the new DLL will work with any existing skin.
    However, while the code was still fresh, I have added a bit of code to it, to allow animated weather icons. It also will allow you to define a custom path, to what weather images you would like to use. This way, no overwriting the default ones in the RR folder
    I also put together a settings screen that lets you change the icons, weather language, update intervals, degree symbol and such right in the skin. It still needs a few last items to be tended to, but here is a quick preview of where it is now. The screen capture quality is not the greatest, and makes the icons look like the animation is stuttering. They move nice and smoothly on the screen, when not recording it however
    My Fiero Build Thread
  2. #1802
    Dec 2008
    choose winamp in RRconfig, not WindowsMediaPlayer
  3. #1803
    Newbie shouryuken's Avatar
    Dec 2007
    Quote Originally Posted by mitchjs View Post
    shouryuken, actually i dont think you should be able to browse album covers at all!!!!!
    unless you are NOT moving!!!
    dont drive near me!
    I dont really mean i fly along the highway @ 100km and flick through the albums.
    But when you have a 3 second window to change an album while your stopped at a light or stopped behind someone etc.
    The way this skin is set up i have to make about 5 touches ( music > Browser> Browser > Albums > Play it ) to get to my albums.
    And add one more to that if im changing it a second time ( up directory ).
    Just wanted a faster way to access it. It cant find a button when changing it on the menu. Nor can i edit any files to make it work
    Thanks for the help to ppl that posted about making a phone work.
    I had worked it out before you guys replied
    Everything works as far as i can tell.... but my phone Omnia 7 is not supported by BS yet
    Using this skin over the last couple of weeks, i have noticed one issue. The skin freezes when i push down volume within the 1st minute or so of use.
    The only way i can get around this is to do something else 1st, like go into Music or Garmin, then go back to the main menu and reduce the volume.
    Once its frozen, Windows 7 will shut RR down, Winamp keeps playing. Then i reopen RR and all is fine.
  4. #1804
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Just did a clean install of Win 7 with latest RR and Latest DFX. Having that issue when trying to close the skin. I tried the "Update DFX" button but that skin appears to be blank and does not function. How do I use option one in the suggested fixes?
    Also I remember talk awhile ago of DFX moving to it's own integrated "RRvoice" of some sort. Has this come to any kind of fruition? Just curious. Thanks as always to you guys, John, Blue.
  5. #1805
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If the update screen is blank or doesn't work, then your DFX5.dll is not the newest. Like if you DL'd a the newer dfx installer but used a older donation patch on top of that, that's about the only reason that it would be like that. Till you get the correct dll to use the skin updater, I'd go with the second option and fix the two lines in the skin exectbl.ini file.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #1806
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by shouryuken View Post
    Voice control: "Play artist the Beatles" "Play Album Abbey Road" Done!
  7. #1807
    Nov 2007
    PA
    Makes sense. My dll is an older donation patch
  8. #1808
    lep
    lep is offline
    Jul 2011
    Rr + dfx5
    RIDE RUNNER WITH DFX5.1.... PROBLEM... TO CLOSE THE RR..... EXIT button not work. The RR NOT CLOSE
    This is because the ONEXIT event has finally been fixed that has not worked properly for a long time, so we did a work around to fix it, but now that it's been fixed, it causes a endless exit loop when you try to exit RideRuner.
    How to fix options:
    #1 5.1.1 users simply need to check for and install all updates and the problem will be gone.
    #2 Open up the skin's ExecTBL.ini file and fix these two lines, right at the top part of the file:
    PHP Code:
    "ONEXIT","BYVAR;FINAL_QUIT;END_CMD<<"
    "END_CMD"
    ,"SETVAR;FINAL_QUIT;1||SENDMSG;SystemListening;ListeningClose||KillColorPicker||ExitFennec||SAVETOSKIN;SKINRELOADING;0||BYVAR;closeplayeronexit;<<KillWinamp||BYVAR;GreetingOnOff;<<CheckResumeSetting||Now_Quit"
    [B]
    do not get it!
    I made the changes in the exectbl.ini, but nothing works
    please someone help me tksss
  9. #1809
    Nov 2010
    Quote Originally Posted by lep View Post
    How to fix options:
    PHP Code:
    "END_CMD"
    [B]
    do not get it!
    try first using the auto skin updater!! and it will fix!
    i have another problem, sometimes, with i rescan the db for new folders or songs... when i choose a artist folder and "play this folder".... it take about 50 seconds to really start playing the musics, it show in the status RESUMEDATA = xx.xx.xx (some numbers here a lot of times for 50 seconds)
  10. #1810
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    John, nice job on the weather so far!
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
