View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1831
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Third, and I'm not sure it's an issue with DFX or RR, but since I updated both RR and DFX at the same time, I cant be sure. The location doesnt work anymore, the one in the GPS etc that tells you the city, state and zip. I know theres a setting in an .ini file, but I set the one I thought was the line and it didnt do anything. There use to be a setting in the config program, but it isnt there anymore.
    The LOCATE cmd aka location RR feature was pulled out of rr and made into a plugin called GPS2City by mitchjs one or two rr releases ago, check your rr history docs. I think its avail in the app store.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1832
    Dec 2006
    me again
    Just installed rrfuel prices which works great (thanks Enforcer) I had to change the keyboard commands as they didnt work with sygic rc11 which was stated in the readme now it works great in carwings loads up sygic and plots a route which is great. when in dfx it loads the iguidance screen with sygic behind. Ive had a look in the skin.ini and the
    exectbl to see if i can find where it says to load this skin so i can change it to the sygic screen
    Question is ...do i need glasses or am i just looking in the wrong place lol
  3. #1833
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by leeharper1 View Post
    me again
    :yay:
    Good to know that actually works for someone, not many people have got back to me with their experiences on the navigation part of it. (Give thanks to Dartman on the sygic integration as we spent quite a bit of time getting it to work)
    Well the command sent from RRFP is GPS followed by the commands to make sygic the active window and then send the keycommands, so you need to look at what the GPS command is being translated into in DFX5. Normally GPS is set in RRConfig, but knowing DFX5 it probably gets changed somewhere.
  4. #1834
    Constant Bitrate overlander's Avatar
    Feb 2008
    Question for all. I'm new to making DFX skins, and I want to add a button and skin for my topographic nav program to my DFX 5.1.1. The program is designed for touchscreens, so there is no requirement for any program buttons around the border of the skin. The only skin buttons I would want to have are the standard music controls available on other screens, and the Menu button of course. This program will also be supplemental to Iguidance, so I want to keep IG intact.
    My question to the group is, with the latest DFX and RR version, what is the best existing skin to modify, and what would be the best and quickest high level approach to implement the skin for this program? Looking for basic steps to do this.
    Looking back through the RR FAQ and Help, it seems those embedding tips are a bit out of date. If there is another thread to guide me through this, would appreciate a link or number. Thanks all.
    Disregard! I forgot I asked this a while back and got an answer! Please delete this post.
  5. #1835
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    You don't really have to modify any skins however If it were me i would duplicate the Dash Command skin and rename it. That pretty much the same concept there. It's all the bottom buttons you need while the top area is available for the program to embed. There are stickies on how to embed any program into RR. For the button there is Button Editor made by Blue ZX3. Should be included some where in the skin.
  6. #1836
    Dec 2006
    Quote Originally Posted by Enforcer View Post
    :yay:
    yeah your right.. I found the line for opening sygic instead of iguidance so now it opens sygic it does however open anothe window in front of it saying calculating route which i believe is also tied into iguidance and is taking focus of the sygic window so it misses the commands sent by the plugin. I an having trouble locating that line so far i was thinking, maybe delaying the output from the plugin until the window has gone, say 5 seconds might work but how do i get the focus back on the sygic screen ???
    this skin seems to favour iguidance for most things..
  7. #1837
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Turn RR debugging on and then have a look at the debug.txt that RR prints.
    You should then be able to see the commands that are sent when the GPS command is sent.
  8. #1838
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Ok. Thank you. I think I have the answer for the other two issues. Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  9. #1839
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Is there somewhere else I can paypal to for the patch. Auto app mart gets stuck in a checkout loop while trying to pay with paypal. Two other people have posted the same issue as far back as early October and nobody from the app store has responded????
  10. #1840
    Nov 2007
    PA
    Im seeing RRFusion was updated with some new skin commands. Im not sure when. Do I need to change these commands or is DFX ready for this?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
