View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1861
    Jun 2002
    Virginia
    You've corrupted your skin.ini. This can happen during an unusual shutdown, but should not happen as a result of normal hibernation. I've hibernated literally thousands of times without problem, but if I do a hard shutdown of the computer, e.g. cut power, while DFX is still loaded, my skin.ini will often fry. Is it possible that you're cutting power before hibernation is fully complete?
  2. #1862
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I use hibernation all the time and never have an issue with my skin.ini.
    But then I don't use DFX.
    DFX relies so heavily on it's skin.ini file that it seems more prone to this issue.
  3. #1863
    Constant Bitrate overlander's Avatar
    Feb 2008
    I actually keep a good copy of my skin.ini zipped exactly for this, but replacing my corrupted skin.ini with the zipped version didn't resolve the updater issue. I'll have to look again at the skin file. what section would populate the updater buttons in skin.ini? I'm suspecting I also need to set my power controller for a longer delay before cutoff.
  4. #1864
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is one thing that I still need to work on, but ATM my focus is on DFXVoice.
    Well...I folded. Working on a built-in backup/check/restore, hopefully will rid this issue for good.
    Update,
    So what I have now is...
    At skin startup:
    If the current skin.ini size is within +/-10% of the last backed up file size, it creates a backup of the current (only keeps last 3 backups)
    If not w/i size limit, then it renames the current skin.ini file, restores from newest backup and reloads the skin with a popup telling you that it restored the skin.ini for you..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #1865
    Feb 2008
    Suuweeeet! U da man.
  6. #1866
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Also, you're updater issue is gonna be only one of two things, but in your case only one. The Btns and labels are done in the skin plugin, so that pretty much means that you have an older skin plugin dll, unless the skin plugin is crashing somewhere causing it to stop working after resume.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #1867
    Feb 2008
    Got it. Which dll filename? The laptop I'm working on has DFX 5.1 loaded as well for testing purposes, and the updater works, so if I can just copy over the file to my carpc, maybe that will prevent a full reinstall.
  8. #1868
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    DFX5\Plugins\DFX\DFX5.dll
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #1869
    Jun 2002
    Virginia
    At skin startup:
    Sweet, Blue!
  10. #1870
    Feb 2008
    So now DFX on my laptop has a blank updater skin in addition to my carputer. I'm lost. You mentioned I may have an older version. my dfx5.dll shows version 1.0.0.0 in the \my documents\riderunner\skins\dfx5\plugins\dfx folder. is that correct or old? not sure how it can be working then bamm, not work.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
