I have the same problem ..... I can't update....
This is my printscreen and I have the same in the carpc
Printable View
Checking on this now and will post findings...
[EDIT]
Ok, found the issue..was the 11/27 update :(
To fix the fubar'd skin updater, go into the DFX5\!SkinUpdates\Backups folder and open up the last zip file and replace your DFX5\Plugins\DFX\dfx5.dll file with the one that was backed up. Then update again, to the current update and all will be fine :)
someone ..... please help me
I need this dfx5.dll your (correct) for downloads. required to fix the update
thanks
Just follow my directions in the above post
Hi,
Sorry to be a pain, I know I ask this every quarter... Will you be adding the feature for the database to remove the songs that I delete as I go.. as I still have to completely delete the database every week & rebuild it to remove the songs from the database....
Happy New Year!
And this is probably the same reply I gave ;). It's in the todo list along with other improvements. I could probably whip up a quick utility that could be run off the rr code to do it till I can get around to working on rrmedia again
Lol, yep always the same answer... :-) whatever is best for you... As you should tell after all this waiting, I am a patient man..
Cheers
Is anyone else having an issue with the gauge screen? I included a screen capture of it. The song title is in the center right hand side and where it suppose to be, is 6 white squares. :lol:
Nope that's correct, the whte squares, it's the millage from the rrvehiclemaintaince plugin.
Yes, I do now see your issue..that song title hanging in the middle of nowhere..left from testing and forgot to remove it. Will be fixed in the next update.
