View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1871
    May 2009
    Ladispoli, ROMA
    Quote Originally Posted by overlander View Post
    So now DFX on my laptop has a blank updater skin in addition to my carputer. I'm lost. You mentioned I may have an older version. my dfx5.dll shows version 1.0.0.0 in the \my documents\riderunner\skins\dfx5\plugins\dfx folder. is that correct or old? not sure how it can be working then bamm, not work.
    I have the same problem ..... I can't update....
    This is my printscreen and I have the same in the carpc
  2. #1872
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by Larry49 View Post
    Same here!
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  3. #1873
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Checking on this now and will post findings...
    [EDIT]
    Ok, found the issue..was the 11/27 update
    To fix the fubar'd skin updater, go into the DFX5\!SkinUpdates\Backups folder and open up the last zip file and replace your DFX5\Plugins\DFX\dfx5.dll file with the one that was backed up. Then update again, to the current update and all will be fine
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #1874
    lep
    lep is offline
    Jul 2011
    someone ..... please help me
    I need this dfx5.dll your (correct) for downloads. required to fix the update
    thanks
  5. #1875
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Just follow my directions in the above post
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #1876
    Jan 2010
    Deleting songs?
    Hi,
    Sorry to be a pain, I know I ask this every quarter... Will you be adding the feature for the database to remove the songs that I delete as I go.. as I still have to completely delete the database every week & rebuild it to remove the songs from the database....
    Happy New Year!
  7. #1877
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And this is probably the same reply I gave . It's in the todo list along with other improvements. I could probably whip up a quick utility that could be run off the rr code to do it till I can get around to working on rrmedia again
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #1878
    Jan 2010
    Lol, yep always the same answer... :-) whatever is best for you... As you should tell after all this waiting, I am a patient man..
    Cheers
  9. #1879
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Is anyone else having an issue with the gauge screen? I included a screen capture of it. The song title is in the center right hand side and where it suppose to be, is 6 white squares.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  10. #1880
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nope that's correct, the whte squares, it's the millage from the rrvehiclemaintaince plugin.
    Yes, I do now see your issue..that song title hanging in the middle of nowhere..left from testing and forgot to remove it. Will be fixed in the next update.
    Last edited by Blue ZX3; 01-12-2012 at 01:09 PM. Reason: updated now that i see the sc better
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
