View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1881
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Hmmm, something happened! RR with DFX is now locking up on button press, right after startup, not an issue with Carwings.
    Ran DFX update yesterday, I think this is the first time I've run RR with DFX since. RR debug doen't give any clues. I'll try disabling plugins.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  2. #1882
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Nope that's correct, it's the millage from the rrvehiclemaintaince plugin
    Really? Ah, ok. lol It just looks...strange...with the song title where it is.
    Thanks.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  3. #1883
    May 2007
    Duarte, CA
    can someone please confirm if 1024x768 res works on this skin.
    i have tried changing it in rrconfig and manual in general.ini, but it always comes out as 800x600
    thanks in advance
  4. #1884
    Raw Wave
    Jun 2002
    Virginia
    Yes, it works fine. In general.ini in the DFX folder change these settings to as follows.
    ShowWidth=1024
    ShowHeight=768
  5. #1885
    May 2007
    Duarte, CA
    yea, i do that, and rr comes up in a window thats 800x600 with 1024xx768 resolution, so the whole screen is NOT filled with rr
    i got 2 pc's and a system format to try, before this really starts to bug me. same thing happens w carwings
  6. #1886
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    ONLY change the general.ini found in the skin folder leave the resolution setting in the config alone and only those two lines, leave the OriginalWidth and OriginalHeight lines along as well.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #1887
    May 2007
    Duarte, CA
    found the problem,... , needed to select 1024x768 install option during dfx setup.
    sorry for troubling you guys, and thanks again
  8. #1888
    Jan 2006
    ok I've been out of the game for several years (DFX 4.0 days) and have decided to jump back in. I've downloaded all the necessary files (latest RR,winamp,Flash and I am currently in the testing phase with DFX 5.1.1) and have run into several issues. First off I cannot get the fonts to line up correctly (everything is cut off)and the track info is now showing up.
    Also having an issue with the weather not showing up. I followed the steps and registered at weather underground and entered my authentication code but still nothing
  9. #1889
    Mar 2004
    Greenacres, WA
    Welcome back to RR and DFX. It's actually gotten harder to make a system work from scratch. My fonts don't look like yours but get cut off. Song-artist-album never gets displayed, weather is a crap shoot, and lets not talk about how most plugins do not work out of the gate, so to speak, or fail after a bit. RR locks up using DFX5, but not with Carwings, DFX Voice doesn't work, RRMaintenance says its missing a language file, etc. etc.
    I'm working on a writeup from the ground up of installing Win7, RR, DFX5 and plugins that will hopefully be of use to people. I just don't know when it will be finished, maybe never.
    It seems like the whole RR experience has regressed, and maybe as the era of the PC starts it's decline, so will the era of Car PCs.
    Sorry for the rant, back to topic.
  10. #1890
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have to completely disagree...
    I went back to Oct posts in this thread and I couldn't find where you posted about said issue...
    The latter one I may have missed, when looking for the your font issue.
    Not really RR's fault, following the directions for the newer version.
    Post a rr debug log and in the dfx skin.ini set the debug=true(is for the skin plugin debug logging) and also post that one (should be in the plugin folder)
    Very vague statement, i know we haven't released a DFX skin settings file for it yet and I know this first hand as have been recently running the DFXVoice in the car with only the default ( aka carwings settings) and it does suck when i know cmds that are in the setup for this skin.
    Imporperly installed RR and or not using most recent plugin version, i just tested this recently with a fresh install.
    While the latter is true, I see it as things slowly getting better, not getting worse.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
