View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 19 of 246 FirstFirst ... 9101112131415161718192021222324252627282969119 ... LastLast
Results 181 to 190 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #181
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by mnwcsult View Post
    thankfully Blue had not run out of spoons.
    must of done the washing up at last lol...
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #182
    Mar 2007
    Nashua, NH
    Quote Originally Posted by meisner View Post
    Is anyone using iGuidance with a line-in device (like HDRadio or XM Radio)? When iGuidance speaks, the music from Winamp pauses or lowers volume (based on the setting I choose). But when I am listenign to HDRadio, line-in does not get muted when iG speaks.
    This works fine with CarWings. But if I switch skins to DFX5 (5.0.3), I loose this functionality.
    Could anyone else confirm this behavior?
    Well, since no one seems to be encountering this problem (or cares to test it out), the workaround is to comment out the following lines in ExecTbl.ini in the DFX5 folder:
    "IGPAUSE","DFXPAUSE"
    "IGRESUME","DFXRESUME"
    I don't know what else is disabled by commenting out these lines, but line-in is now muted when iG speaks.
  3. #183
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Will add to the to check list.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #184
    Mar 2007
    Nashua, NH
    But does DFXPAUSE/DFXRESUME add any value over IGPAUSE/IGRESUME??
  5. #185
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Thumbs up
    Hi blue, I have another modified m3u file for internet radio, maybe you could add this to next skin update? If not then ........Enjoy all. Oh, the Rock m3u that is in last update, there is a discontinued url........>Mr Poo Poo's Iron Maiden .....Dead no longer. What a shame, I had this for 3 months with no problems Just delete url from the Rock m3u........Sorry.
  6. #186
    Jul 2006
    Blue I hope my post earlier didn't come of too snarky, I'd just spent all weekend (the second consecutive one) trying to get everything running smooth to put it in the car and a little frustrated that it felt I hadn't made much progress. But anyway yes removed zips.dat and the gauges screen is all functioning as it should!
    The latest issue I'm having is substantial lag througout although it's most noticable when skipping tracks. When I skip tracks (also pause/change menus) the next song starts playing immediately but the entire skin locks up for ~8 seconds before I can do anything else. I don't think it's lack of processing power, DFX4.0 was lightning fast even when I had a 15k+ playlist on the go.
    Hardware wise it's a dualcore atom 330 (i945GC) with 2GB of ram.
    Video of the the lag I'm experiencing. With hindsight Daft Punk might not have been the best artist to have playing! It might sound like it's skipping at times but the audio is playing as it should throughout the vid.
  7. #187
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ya, i have a MB board that has that same atom proc and it doesn't even have to grunt at all, more that i can say for my last board...M10K
    What player, as maybe could be a player issue. You should have no lag when skipping to the next/prev tracks especially with that proc. Could be something on/up with your setup some where as i can't recall anyone else reporting this lag your experiencing...
    Are you connected to the net when trying this? Just thinking also maybe the player is trying to grab some kind of info for the current track and holding RR up in the process, IDK?
    Just had another thought, video drivers correct or up to date? Vid drvs can create all sorts of issues....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #188
    Sep 2003
    Thousand Oak, Ca
    I'm trying to get OBDMPG screen going. Does this require the plugin or is it built in? What setup is required if it's built in.
    Great job, thanks for all your work. And I have donated!
  9. #189
    Jul 2006
    Yep somethings definately not right I'm stumped though, not connected to the net. Player is Winamp 5.something, not sure which, latest one as of a week or so ago.
    It's a fresh windows install xp pro x86. First thing I did was chipset/video drivers/audio lan drivers. Then went through windows update (service pack updates etc), all .net updates, then flash player, klite codec pack standard, Riderunner/dfx has been uninstalled twice but I deleted remaining folders and rebooted between uninstalling and reinstalling. That's just made me think though does anything persist in documents and settings that could be screwing things up? I only deleted the riderunner folder in c:\program files
    I'm going to go pull it out the car now and do a fresh install of RR/DFX then run it without changing anything and see if it lags. Chances are I'm screwing something up somewhere along the line configuring it...
    @trader007 I got hold of a andrea array mic and usb adapter today and have just been testing it on my windows 7 rig. The difference is like night and day! Admittedly I'm in a quiet room but results have gone from ~10% accuracy and not even being able to recognise certain words; to near 100% accuracy on carefully pronounced words and dictating around full normal conversation speed with very high sucess rate! Quite astonishing the difference it's made.
  10. #190
    Jul 2006
    Okay quick question; what components should I be checking/unchecking when I install winamp? winamp agent? media library? multimedia engine?
    Could any of these be affecting operation of winamp within RR?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
