View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1901
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by DaveDog View Post
    DFX Voice is installed and enabled, but the new microphone logo does not show, just the old one and there is just a beep when pressing it. I did see the new microphone after it was first installed, never came back after a reboot.
    I found something, in the topindicators.txt file, the RRVoice settings were enabled and the DFXVoice settings were disabled /. Reversing this, and the DFXVoice microphone appears, and when its pressed, the windows pops up 'listening', but never goes away and any press causes a not responding issue.
    Plugin Manager does not show RRVoice installed, only DFXVoice.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  2. #1902
    Apr 2010
    Font issue
    Quote Originally Posted by hpric View Post
    ok I've been out of the game for several years (DFX 4.0 days) and have decided to jump back in. I've downloaded all the necessary files (latest RR,winamp,Flash and I am currently in the testing phase with DFX 5.1.1) and have run into several issues. First off I cannot get the fonts to line up correctly (everything is cut off)and the track info is now showing up.
    Also having an issue with the weather not showing up. I followed the steps and registered at weather underground and entered my authentication code but still nothing
    hpric,
    Don't know if this will help, but I had a similar situation with my fonts not lining up. Then I remembered that I had tried to compensate for my geezer eyesight by increasing the font and icon size in windows. FWIW, try this: right-click on your windows desktop, click on screen resolution, click on the "Make text and other items larger or smaller" option, select "Smaller-100%" and then exit out. Start DFX5.1 and see if there is any improvement.
  3. #1903
    Jan 2006
    Quote Originally Posted by twjlaw View Post
    hpric,
    Yea this has already been resolved, thanks
  4. #1904
    May 2007
    Duarte, CA
    i have searched all over the forum/google, and cant find out why the text on top is being cut-off slightly. can some one please help me out.
    resolution is 1024x768, and it appears to be happening on any font i use
  5. #1905
    MySQL Error
    Oct 2004
    set you desktop fonts to 100%
    try that
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #1906
    May 2007
    Duarte, CA
    I made sure fonts were 100% on both carpc and the laptop. Is there anyway to make 85%? Does no one else have this problem on 1024x768?
    I know its still early, so hopefully tomorrow I will have more solutions
  7. #1907
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by 4puteruser View Post
    Yes, I do on 1024x768. Have not yet tried setting fonts to 100%, if that fails, I'm going to the 800x600 skins.
  8. #1908
    MySQL Error
    Oct 2004
    set fonts at 100%
    at 1024 x 768 should be fine...
    then if the font isnt right... post
    i cant imagine resolution makes a difference on font... but font scaling DOES!!!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1909
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by mitchjs View Post
    set fonts at 100%
    Unfortunately, since the beginning of Road Runner, it has never properly scaled the fonts at different resolutions. The skin is written with 800 x 600 in mind. If you switch the show width and height in the gereral.ini to 1024 x 768, the font scaling gets all out of whack. Especially noticeable in larger fonts, like those along the bottom of the screen for music control volume ect.
    To test, take an 800 x 600 skin (DFX for example), and change JUST the show width / height, and NOTHING else. You will see what happens. For some reason, the larger the font, the worse the scaling gets out of proportion.
    There are a couple version of the bottom row buttons in the skin folder you can rename to help compensate, one for 800 x 600, one for 800 x 480 and another for 1024 x 768. This only fixes the bottom buttons, and nothing else in the skin. That would take altering each and every skin file for the different resolutions
    My Fiero Build Thread
  10. #1910
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    What I did was just use the skin editor, go to #1898 post.
    Because my res for test pc is 1280x800
    I backed up the altered skin files, and then wrote down my changes just in case.
    And I also backed up my loader.skin file and splash.jpg file, I altered them too.
    Good luck.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
