View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #1941
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The installer installs it to the right location depending on what mode RR is running in, Legacy or Profile.
    Any time you have a MyDocs\RR anything more than likely RR is installed in Profile mode (must under vista/W7, optional in XP)
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #1942
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    RRVoice doesn't have an installer that I know of. It is Drag 'N' Drop files. There is a Register.bat file that opens up real quick & exits but thats it.
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  3. #1943
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It (RRVoice) should be installed in the Prog Files\RR\Plugins\RRVoice folder
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #1944
    Feb 2005
    Huntsville, AL
    If I move it out of the DFX plugin folder and put it into the program files\RideRunner\etc it does the same problem as stated in the above posts.
    I'm thinking of reinstalling Microsoft Office to reinstall speach recognition and see if that help with the run-time error.
    Any other Microsoft packages that I can reinstall that might help?
    Thanks for all your help
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  5. #1945
    May 2008
    Bend, OR
    I'm pretty sure that was fixed in one of the skin updates. Is your skin up to date? (2-10-2012) You also didn't mention from what RR version you upgraded from. Otherwise, we have another problem again b/c of an RR update.
    I get the same blue boxes in the youtube preview page. (feb rr and 2/10 dfx)
    What are the odds of adding a script to delete the weather xml's so that it updates properly? Is that something I could do myself somehow.
    [Edit by Blue ZX3]
    This was a weather plugin issue and has now been fixed, see the new weather plugin thread for a newer version.
  6. #1946
    Jan 2006
    reinstalled the RRMEDIa pluggin and now its working
  7. #1947
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by michaelrj9 View Post
    You SHOULD have a DFX\Plugins\RRVoice folder, and it should only have two files, menu.ini and rrvoice.ini. The plugin gets put in with the rest of the other plugins and uses the folder in the skin folder to give it customized settings/opts for that particular skin.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #1948
    Jan 2012
    UK
    I'm getting a crash when trying to exit the video skin when playing a movie, I've tried on carwings and that works fine. My video player is set to vlc and video is playing fine, it's just when pressing the menu button, even tried pausing the movie & then menu, both give the same crash.
    This is that last 2 lines of the debug log.
    12/02/2012 20:47:51: Que Exec: True, video_player.skin, "ESC||GammaSlider", False
    12/02/2012 20:47:51: Executing: ESC
  9. #1949
    Jan 2012
    UK
    OK, just fix my fault, by removing "||GammaSlider" from the following line in video_player.skin.
    B12,1,519,97,79,"ESC"||GammaSlider",@LOAD;menu.ski n@
    What is GammaSlider?
  10. #1950
    May 2008
    Bend, OR
    Okay I'm a little confused. What is the correct sequence to download the most up to date version? I pulled the dfx 5.1.1 setup then the patch. However now I can't find the skin update button.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
