It is ResumeMusic=2 and the resume function works well on all other situations except the video.
It looks the same like if you change something in RRConfig app and then start RR. No music resume and not showing times in the progress bar.
Printable View
yes, rrconfig, delete resume information, as it should..
i tested DFX5, it resumes just fine...
went from Video, to menus... and music plays...
my suggestion would be to debug your own situation, and review the debug.txt
maybe you have a STOP command in there... you forgot you put in :)
Has anyone ever had ilists just not display? I did another clean install, and the button chooser list is blank for some reason.
I will spend some time this weekend going over the last few issues brought up, getting an up to date installer uploaded to the app store, ect...
Horray.....and then RRMediaDB ,I hope.:yum::high5::dance:
Hi guys, I am still working on a little house keeping issues. I had reinstalled a fresh March version of RR and a full DFX5.1, but as soon as I got the weather underground API code figured out DFX stopped working. When I start RR w/ DFX, it displays the first menu page with all the button box's, but no text or icons. If I try to access any of the buttons nothing happens. I reinstalled DFX, still the same. I am not preloading any screens. Any ideas?
All that is stored in the skin.ini...
Blue, so you are saying that the skin.ini is corrupt? If yes, how do I get it back? I tried to reinstall DFX and its still blank. How do I prevent this?. Also is there a problem with DFX and some computers that use hibernation? With my two carputers, it seems over a period of over several months that when using the DFX skin (I prefer to shutdown in hibrination) , it starts to run a little odd or stops RR from running at all (locks up). And then all I can do is switch to Carwings till I can reinstall DFX.
woot post 2000 (sorry had to) :horn:
