View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2051
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    As to be expected, the new release of RRMaintenance doesn't play well with the latest DFX5
    Quote Originally Posted by GizmoQ View Post
    Better check you skin with Carwings first.
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  2. #2052
    May 2008
    Bend, OR
    In Engineering the motto is: "If it ain't broke, take it apart and figure out why!"
  3. #2053
    Mar 2004
    Greenacres, WA
    -FYI -
    Win 7 users, do not install DFX Voice with the new version of DFX skin.
    without even trying to use DFX Voice, RR locks up when DFX loads up, sometimes you have to press a button.
    Carwings didn't lock up, deleting DFX5 completely from the system and re-installing didn't fix it, removing DFX Voice fixed it.
  4. #2054
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You surely like to leave out details don't you.... I/we can't possibly fix whatever it is that your saying that is incompatible between the updated installer and DFXVoice. Its always in the details!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2055
    Mar 2004
    Greenacres, WA
    Sorry, updated the post.
    Let me know if I can assist any further.
  6. #2056
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I do have W7 on my lappy so I'll see if I can muster up the same thing your getting...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #2057
    Mar 2012
    Quote Originally Posted by cd36 View Post
    So, I seem to be having trouble getting WMA Tags to show. I'm using Winamp, and the tags show fine in Winamp. My file browser displays correctly as well (don't know if the browser shows based on tags or file structure), but no tag information will show in the player, or in the header on the main menu. I've tried rebuilding the database, with no help. Any help would be appreciated, thanks!
    Anyone have any suggestions? I'm testing on my desktop which is running Vista, but RR and DFX seem to work perfectly in every other way, just no WMA Tag information is shown. After doing some searching it seems that RRMedia builds its database based on the tag information, so I don't know how it can build the database on Tag information, but then lose it when it comes time to show it in the player. I thought I had this working at one point, but I've been playing around with it so much I can't remember for sure. I tried uninstalling RR and DFX, and reinstalling them, but that didn't help. THanks!
  8. #2058
    Nov 2010
    try to do some changes at RRCONFIG -> Music ->Tags & Formatting
  9. #2059
    Mar 2012
    Quote Originally Posted by DefaultBR View Post
    Anything in specific to change? I've tried changing changing the tag type in their between all settings without any luck, anyways it seems to be dealing with ID3 tags, which WMA doesn't use. What setting should WMA files be on? Thanks!
  10. #2060
    May 2008
    Bend, OR
    Okay follow your own logic there. 'seems to deal with ID3 tags, which WMA doesn't use'. You've clearly checked the settings list and not seen wma tags, yes? So, logical conclusion, sadly RR does not read wma tags.
    If you asked is there a hidden setting to make RR use WMA tags. Well different story: Have you tried having it just use the file information?
    *editing papers makes you a logic and grammar nazi*
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
