View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2081
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by michaelrj9 View Post
    I think I may have found my problem. I am using a different voice than the ones microsoft gives you. It is from Acapela I don't know if it was a trial or got corrupt but either way it won't work if I reinstall it. Must be a trial (causing the same problem) after a image restore. Never said it was a trial or trial expired etc.
    Do you, or anyone know where I can get free alternatives or buy any custom voices that sound more realistic than the microsoft ones?
    Well out of all the confusion, that would sound like the most likely canidate...
    From a quick search, you can buy various voices here: http://www.nextup.com/TextAloud/
    but you have have at least one of their SW's installed to use the voices out side of their SW which allows them to sell them (voices) at a much lower cost then just buying the voices outright which is usually much more costly.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2082
    Apr 2012
    querying database debug files
    RRMedia(Main)_debug.old.txtRRMedia(Main)_debug.txtI confirmed that I have the folderscache.cache
    Attached debug file
  3. #2083
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    See about the logs again, but also have RR's debug on and zip attach all the logs, RRMedia & RR's from a session.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #2084
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Thanks for the link.
    Quick question. Long description
    I have been also searching too and it seems like any of the natural sounding voices need a stand alone program for them to work like you said.
    I was trying them out but I still get the DFXSpeak error message (but DFXVoice still works correctly even though I get the error message) after everything is booted up. Which isn't horrible at least it works now but still shows the message.
    It is caused by DFX Skin loading up before the other program is loaded up upon Windows starting up.
    Is there a way to disable the error message, hide it or delay it and or maybe a way to delay RR so the other program has a chance to finish loading up?
    I don't use any greeting upon DFX loading up but when the skin loads it must check (SAPI?) and knows it can't access the voice causing the message.
    Thanks for all your help!!!
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  5. #2085
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well, DFXVoice & DFXSpeak do use SAPI, but use totally different parts of it, V Recognition and Text to speech. So just b/c one works doesn't mean the other follow suit. "other program is loaded up upon Windows starting up"??? Does Starting RR after win is finished loading do the same thing?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #2086
    Feb 2005
    Huntsville, AL
    RR is in the startup folder so it starts up automatically when Windows boots up. TextAloud is also setup to start automatically within the options of the program. This way I still get the DFXVoice error message when Windows & RR loads up automatically But the DFXVoice part still works. I can ask what time is it etc and it responds like it should. I just have the error message that popped up whe RR first loaded up.
    If I start RR manually after Windows is finished loaded up with TextAloud it works great with no errors.
    It's not that big of deal but would like to hide it-remove it if possible.
    I was hoping for a way to hide the DFXVoice error message or even delay RR OR DFX for a couple seconds to allow Windows to finish loading up TextAloud first so I don't get the error message.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #2087
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have some issue with DFX5.1.2 .
    1-When i want to quit RR, RR don't see several commands into the line that follow:
    "END_CMD","SaveExitStaus||SENDMSG;SystemListening; ListeningClose||KillColorPicker||ExitTwitter||ExitFennec||SAVETOSKIN;SKINRELOADING;0||BYVAR;closeplayerone xit;<<KillWinamp||BYVAR;GreetingOnOff;<<CheckResumeSetting||Now_Qu it"
    2-I try to adapt my plugin RRGoogleMapsTools for the DFX5 skin but DFX freeze when i try to load my first screen !
    Into this first command , my plugin launch these lines:
    load;RRGoogleMapsTools.skin||RUN;;GmapsApiForm
    that load my main screen
    and
    CreateGpsToAdd_Html()
    GmapsBrowser.go(MainPath & "gmaps_gpstoadd.html")
    that create and load my html file !
    My plugin run very well with the Carwings skin or an other skin as Reborn!
    Where the issue please !
  8. #2088
    May 2008
    Bordeaux, France
    After to have read the second post i have solved my RR exit but i have always my first issue !
  9. #2089
    May 2008
    Bordeaux, France
    I have found where is my issue with DFX5.
    My plugin don't accept that i launch it when i am on the main menu screen, but if i load , by example, the plugin manager screen, i can load my plugin and RR don't freeze!
    An idea please ?
  10. #2090
    May 2008
    Bordeaux, France
    I had also an old issue when the new format indicators when the indicators are also defined with the IND option !
    So i have modified into the TopIndicators.txt file the lines that follow:
    I01,15,9,40,20,"REPEAT"
    I02,67,9,40,20,"SHUFFLE"
    I03,143,9,40,20,"ONLINE"
    I04,278,9,40,20,"DriveNotification_CD"
    I05,330,9,40,20,"DriveNotification_DVD"
    I06,390,9,40,20,"mobilephone_connected"
    I07,445,9,40,20,"FBCONNECTED"
    IND,FBCONNECTED,Indicators\FusionBrain_Off.png,Ind icators\FusionBrain_On.png
    I08,500,9,40,20,"RRSkype"
    I09,555,9,40,20,"RRVM_CheckMaintenance:B",5000,200
    IND,RRVM_CheckMaintenance,Indicators\VehicleMainte nance_Off.png,Indicators\VehicleMaintenance_On.png
    by
    I01,15,9,40,20,"REPEAT",,,"Indicators\REPEAT_*.png "
    I02,67,9,40,20,"SHUFFLE",,,"Indicators\Shuffle_*.p ng"
    I03,143,9,40,20,"ONLINE",,,"Indicators\WiFi_*.png"
    I04,278,9,40,20,"DriveNotification_CD",,,"Indicato rs\CD_*.png"
    I05,330,9,40,20,"DriveNotification_DVD",,,"Indicat ors\DVD_*.png"
    I06,390,9,40,20,"mobilephone_connected",,,"Indicat ors\Phone_*.png"
    I07,445,9,40,20,"FBCONNECTED",,,"Indicators\Fusion Brain_*.png"
    I08,500,9,40,20,"RRSkype",,,"Indicators\Skype_*.pn g"
    I09,555,9,40,20,"RRVM_CheckMaintenance:B",5000,200 ,"Indicators\VehicleMaintenance_*.png"
    With this format my indicators are not superimposed by a bad indicator !
    I don't know if you will accept this new format but that would be a good idea !
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
