Is there a way to disable the animated weather icons, for some reason the weather icons appear fine on the weather screen. However, they won't appear on the main screen. The text is there, just no icons of any kind.
I have noticed that in the Cover Art Album Browser, there are no longer ilists for the song lists, but icons instead. I have researched this quite a bit, and it seems like a couple of commands have been removed from the Exec.ini and the call for Album Thumb Browser 2 skin is never made. The Album Thumb Browser skin handles the whole job hence icons instead of ilists for the song titles.
I believe that the change happened when the TBPlayAlbum command went into effect, instead of the !Select etc command.
Any way to add the ilists back to the song lists for the Album Thumb Browser.
CAR: 2007 G35 Sport Coupe 5AT
HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Nice thanks! I'm waiting on the 300$ pin crimper to make connectors for the Via board. Why the hell they used 2mm pins ugh.
hello. i know im a noob here with my mimal posts n all, but im pretty savy when i comes to figuring this type of stuff out. i searched on the dfx help and through this thread and havn't found an answer.... ive got an eee pc tablet im planning on using as the puter/display. got ride runner installed and music/playlists setup. this is the most important aspect to me..the music. but obviously simplicity is what everybody wants and so far so good. but my problem is that once i have a playlist loaded, lets say i want to select a song from the...idk what you call it....the section that shows the list of music...in order to play it you have to double click it. this is fine if your using a mouse, but for TS, single click for any type of command is what is prefferred. is there a reason for this or do i not have something configured properly for this. most other parts of the FE are single click which is great. but if i want to change a song using the list, i have to double click with my finger and i personally find that annoying... is there a setting to change this or is this something that is built into the program and i just have to deal with it? sorry if this has been asked and aswered before but i couldnt find an answer.... thanks
Check in the RR config there is a setting for that. I believe that it should work the same with the DFX Skin. If not i'm sure someone will correct me.
In the RRConfig under the music section then modes Check "Play on list click"
That should do it.
Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
1.)Orion 2500d Amp
1.)Orion 15" h2 Sub
1.)Orion 8004 Amp
2.) Sets Orion Components - P-SERIES
thanks for the insanely fast response!! lol im assuming your talking about the "play on list click" under the "modes" section. i have that enabled and it does work with the mouse pad. if i move cursor to a song, and tap pad/left click, it will play with single click. but it for some reason does not recognize a touch input. even with the stylus. all other buttons recognize touch and do what they are supposed to but in the list, it just wont recognize it. if thats not the setting, then which part in rr config should i be looking at?
About my post #2087, i have added these two lines into my exectbl.ini file and my RR Exit is now easier !
"ExitFennec","RunQ;$skinpath$scripts\Kill_Task.exe |Fennec.exe"
"KillWinamp","RunQ;$skinpath$scripts\Kill_Task.exe |Winamp.exe"
1.)Orion 2500d Amp
1.)Orion 15" h2 Sub
1.)Orion 8004 Amp
