View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2101
    Apr 2012
    Fredonia, NY
    Semi-exoerienced noob
    .Hey there, all. First off, I love this site. I've been messing around with this stuff for a while, on and off, and as long as my wife doesn't kill me, shall continue to do so. I am having a problem with dfx 5.1. I've had it working fine before but now, when I start it and click on a menu, it freezes. I can't seem to figure this out. I have winamp 5.13, all win7 updates, and june 2010 dist for directx. What am I missing? I've searched but to no avail. Please help!
  2. #2102
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    About my post #2087, i have added these two lines into my exectbl.ini file and my RR Exit is now easier !
    just noticting this... killing winamp is a bad idea... let RR close it... if its hanging, solve the problem
    dont kill the task...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #2103
    May 2009
    Ladispoli, ROMA
    HellÚ, I have a little problem, I can't open any GPS program from MENU_1 but if I open Music and gps all is ok, can someone tell me why?
    thank-you
  4. #2104
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by mitchjs View Post
    Your forgetting that a bigger delay was added to this, for those times when RR can't/won't/don't close winamp
    Current operation of this is:
    First it waits 5 secs, attempts to tell winamp to close (same way like RR) if its still running , waits 2.4 secs, rechecks if its still open, then if still open, then terminates its process
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2105
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by a1dznr View Post
    First, before anyone else tells you...update winamp to current, we are no longer saying to only use 5.13. I'll follow that up with turn on RR's debug and look at the log and/or attach here to help narrow the issue down as your "click on a menu, it freezes" is a bit vague when dealing with such a complex skin.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #2106
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Ba11s Deep View Post
    I have attached a zip of the debug files for both rr and rrmedia. thanks for any assistance you can provide.
    Couple of fixes,
    In your RR\plugins\RRmedia folder open up the storepath.ini and remove that trailing backslash. Not causing any harm but not correct either.
    With RR closed, go to the storepath\cache location, and delete any non *.cache files. Startup RR, goto the browser, check if you now have a _db.txt in your cache folder, which should match the foldercache.cache file.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #2107
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Music Not Showing/Resuming after Always or Start/Hibernation setting
    I am having a problem with DFX5 with the music resuming. After starting RR from cold boot or hibernation, go to to start DFX5, get to the main menu screen, the music does not show or resume the last playlist/song. I have to hit the Music icon to go the audio player so it can start playing (and it always start from beginning). I have selected in rrconfig Resume "always" and "start/hibernation". It does the same thing for both. I also have renamed resume.ini to create a new one but it does the same thing.
    Any ideas of what I am doing wrong? I had this working fine before.
    DFX 5 (latest updates from skin)
    Winamp 5.601
    RR April
    I am attaching the debug file as well.
    Attached Files Attached Files
    Gee
  8. #2108
    MySQL Error
    Oct 2004
    well.. after you RESUME AT
    4/28/2012 1:32:23 PM: ResumeFromHibernate: (start)
    4/28/2012 1:32:27 PM: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
    4/28/2012 1:32:27 PM: INFO: LoadResume() - Reading resume data from C:\Program Files\RideRunner\resume.ini
    4/28/2012 1:32:27 PM: AudPlayerStart: music player: PLPosition=0 TrackPosition=51628
    4/28/2012 1:32:27 PM: AudPlayerStart: player volume be 0: 0
    4/28/2012 1:32:27 PM: AudPlayerStart: player should be playing: PLAYING
    4/28/2012 1:32:27 PM: Enter Exec: False, exit_menu.skin, , False
    4/28/2012 1:32:27 PM: Que Exec: True, exit_menu.skin, "OFFLINE", False
    4/28/2012 1:32:27 PM: Leave Exec: False, exit_menu.skin, OFFLINE, False
    4/28/2012 1:32:27 PM: AudPlayerStart: Player.GetTrackLength: 348000
    4/28/2012 1:32:27 PM: AudPlayerStart: Player.SetTrackPosition: 51628
    4/28/2012 1:32:28 PM: INFO: CheckResume() - Resuming to music player: PLAYING
    sure looks like its playing...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #2109
    Nov 2010
    Quote Originally Posted by navputer View Post
    Winamp 5.601
    RR April
    i have this problem too!!! i think when you click in the music, it do a "Refresh" and finally load playlist/last song, so you can play music normally again, but in the next hibernate resume, the same problem =/!!
    but its so normal for me now to click in music button to load the playlist, that i forgot to say this problem here!!
  10. #2110
    MySQL Error
    Oct 2004
    from resume? or from fresh start?
    just look at you own debug.. its pretty easy to see what rr is told to do
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
