View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2111
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Music Not Showing/Resuming after Always or Start/Hibernation setting (Continue)
    Ok...I looked at the debug file too and it looks like it should be playing on the Main Menu screen but it does not actually starting playing until I go to Audio Player (hit Music icon) screen. So, I tried this with Carwings Dynamic lite too and got the same thing.
    I have attached another debug file just in case with me doing this with the Carwings skin. I don't really use this one but tried it for testing purposes.
    Attached Files Attached Files
    Gee
  2. #2112
    MySQL Error
    Oct 2004
    there is no resume data, so its not going to resume...
    4/28/2012 5:49:06 PM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    4/28/2012 5:49:06 PM: INFO: CheckResume() - No Resume Info
    try going to music (Audio_Player), pick a song, get it playing... exit to menu... exit rr
    then start rr back up, it will resume...
    and you should be able to analyze your own debug.txt... you would have seen that...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #2113
    Jan 2007
    DFW Area
    Quote Originally Posted by mitchjs View Post
    Right, I saw that I did not have any resume data and I didn't see a resume.ini file as well. I was going from a cold boot, RR in startup, get the main screen and no music although when I left the skin (to shutdown, etc.), I had music playing. So, I thought Resume mode = always or start/hibernation would continue playing the music where I left off.
    I tried what you mentioned and it worked that way. I must don't understand the Resume mode because I thought resume mode = "always" will play the last playlist/song when I start the skin.
    Gee
  4. #2114
    MySQL Error
    Oct 2004
    always... when it has resume data... which it will unless, 1 rrconfig is run, 2 installing of rr, 3 you delete the file, 4 you have no songs in PL
    both rrconfig and installing rr, deletes the resume.ini as standard practice
    simply changing skins in rrconfig... would delete resume.ini
    so... unless your running HORM, and not properally set up (ie horm settings in rr), when you EXIT rr, it will save RESUME data (also going into hibernation)
    and the next run of RR it will resume...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #2115
    Apr 2012
    Fredonia, NY
    Here's the log. I did notice that everything works fine when I turn off visualazations for any music player in rrconfig. I'm runnng directx 11 and have no graphics problems so it must be a setting I'm missing somewhere. Also, I have updated winamp
  6. #2116
    MySQL Error
    Oct 2004
    Quote Originally Posted by a1dznr View Post
    do you want anyone to do anything with your debug.txt...
    what are we looking for?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #2117
    Apr 2012
    Fredonia, NY
    First, before anyone else tells you...update winamp to current, we are no longer saying to only use 5.13. I'll follow that up with turn on RR's debug and look at the log and/or attach here to help narrow the issue down as your "click on a menu, it freezes" is a bit vague when dealing with such a complex skin.
    I've updated to latest winamp and still have the freezing problem. It happens with wmp also. Same issue with carwings, too. I figure that it must be a setting that I'm missing. could someone please look at this log file and see what they think? I've had this working before on a previous install (hard drive died so had to start over with a new one). This is really driving me nuts.
  8. #2118
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    From that log, looks like you went into the weather screen, when it froze up. Now, is this freezing problem when going into any scrn, or just say the weather one? Same exactly for carwings skin, right?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #2119
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    my setups (all 3) also lock up, especially if I press buttons too quickly, its worse with DFX than with Carwings, and worse on my atom based systems than the one with a faster processor. I've just given up and live with going to task manager, killing riderunner and restarting, remembering to press a button only once every 2 seconds.
    I could go on with all of the other issues, but no one really seems to be interested.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  10. #2120
    May 2008
    Bend, OR
    Hi blue, any word on the updates?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
