View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2121
    MySQL Error
    Oct 2004
    Quote Originally Posted by DaveDog View Post
    my setups (all 3) also lock up, especially if I press buttons too quickly, its worse with DFX than with Carwings, and worse on my atom based systems than the one with a faster processor. I've just given up and live with going to task manager, killing riderunner and restarting, remembering to press a button only once every 2 seconds.
    I could go on with all of the other issues, but no one really seems to be interested.
    there prob is some common issue with all your setups.... a plugin... something...
    i go real fast, never a lock up...
    granted im on a fast system, but most systems are fast, its not that much cpu usage for RR
    remove all the plugins... slim it down...
    easy way to remove plugins, rename the plugins dir to like plugins disabled...
    and if you have a RR issue, post it in the main forum... i dont always read this thread... just time to time
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #2122
    Constant Bitrate besjr69's Avatar
    Feb 2011
    I have the same issue with Carwings and DFX. The only skin that works reliably for me is the eLite series. Really like DFX and would like to use. Could it be the size of my library? 109GB. Please hold all the comments about how crazy this may sound. My preference.
    Sent from my iPhone using Tapatalk
  3. #2123
    MySQL Error
    Oct 2004
    i see a lot of people saying "same issue", i have no idea what that "issue" is
    if there is a legit issue, it can be solved...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #2124
    Feb 2011
    Mitch,
    The issue is that RR becomes unresponsive whenever a key is press. I don't believe the "issue" is with DFX or Carwings. I believe it is with RRMedia and the size of the library. The skin I use without this issues does NOT load the RRMedia plugin or doesn't use it. I'm going to test this theory over the next couple of days on my Desktop PC which has a huge MP3 library. There may be a limitation with RRMedia that's has been over looked like the total number of files or something. Anyway, I will post to a general forum with my finding and not clutter up this thread.
    Bobby
  5. #2125
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    I believe that I was having the same problem. Uninstall RR, DFX and Winamp. Reinstall Winamp first, then continue with RR and DFX and see if that clears up the problem. If I remember correctly that is what solved it for me.
    Mitch,
    Bobby
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  6. #2126
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by besjr69
    Mitch,
    When talking about Size and RRMedia, better to say # of songs/files as size is varient depending on what type of files you mostly have and their quality. Yes, at one point, there was a song count limit(bug) but that has long been fixed.
    Now, I can't really see RRMedia being the issue here, the only thing that comes to mind with this would be those users that try to load a crap load of songs or their entire collection into a playlist (WTF...). That has and probably will always be an issue with RR, I'm talking about a playlist with 10K+ songs or more type thing.
    Quote Originally Posted by steven765
    Hi blue, any word on the updates?
    The only word I have on them is that I need to do the finishing work on them, and put em up. John has taken a break for a while (how long, IDK??), so right now anything skin related is being taken care of by me, along with everything else that I have on my plate ATM. I will get them out when I can...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #2127
    MySQL Error
    Oct 2004
    Quote Originally Posted by besjr69 View Post
    Mitch,
    Bobby
    what does "a key is press" mean...
    like when u touch a letter on your keyboard?
    carwings doesnt use RRMedia...
    disable all plugins (yea rrmedia is prob a bit active all the time, even with carwings)
    the way to disable plugins, is easy, rename the plugins folder, to like plugins disabled...
    might want to keep skintool around
    then u can test with carwings....
    keep in mind, ANY plugin can make RR die, there is no way to prevent that
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #2128
    Feb 2011
    Well I guess I've said it wrong. Basically, whenever you touch any button on the skin RR will become unresponsive and you'd have to force close RR in the task manager. Initially, I thought the issues was with the RRVM plugin (last plugin installed before this started happening). I removed it (deleted from the RR install folder and skin folders) and still got the lockups. So I started thinking maybe it had something to do with RRMedia. I came to this after I manually removed the RRMedia.DB and rating_ files from my music folder and edited out the folder entries in the music settings. When I pressed the music button after doing this, I was able to navigate the skin and rebuild the library. My library has 31,762 files. It takes RRMedia 8:26 to build the DB on my desktop PC. Generally, I que up an album and play it. I will test without using RRMedia and see how things are. Again, I don't believe this issues is with DFX, Carwings or a plugin (minimal install and still have the issues). I think the issue may be with the size of the library I'm using. Oh and RRMedia does load when using Carwings, but is not used. It is not loaded when I use the eLite skins. It doesn't show in the task manager or task bar.
    Bobby
  9. #2129
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Number of songs is not going to be the factor here, I'm have 43k+, and I'll just guess that by now, John is in the 51-52K range and there are no issues of lockup/freezing here. Just some food for thought....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #2130
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Yep, that's the issue I run into, (along with RRVoice not working, HDRadio resetting stations, makes me wonder if anyone is actually using RR anymore)
    I'm pretty sure its not RRMedia, as I only have about 1400 songs, and the fact it does it in Carwings also, just not as common. I've learned to press "buttons" slowly
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
