Note about the weather settings, it's only the animated one that won't work on the front page. Just use the non animated ones and it works great! Blue thanks a ton I know this is a lot.
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
That was before the latest installer build, so you will not need it.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
So, I shouldn't install RRMedia 1.3.0 over it?
Thanks!
No, I have not updated the RRMedia installer.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I'm back on the topic of RR becoming unresponsive after a button is pressed. I wiped RR completely from my system (directories, plugins, skins, everything) and incrementally installed everything back. With only RR and Carwings as skin, I ran for two days without issue. Next I installed DFX and everything ran flawlessly (all menus worked, rebuilt database, sirius, etc) until I went into the settings menu. While attempting to change the Logo, I received a BSOD with xPort being the culprit. After reboot, I disable xPort and ran DFX. The unresponsiveness returned. Could this issue possibly be a COM port issue? I noticed that DFX uses the GPS stream for the directional arrow and compass. Is there a baud restriction with this? I'm currently streaming at 38400 on COM5 and outputting to COM2 and COM7.
Tomorrow I'll set the GPS port to "NONE" in RRConfig and see if the issue goes away.
Bobby
So I just made a paypal donation for the skin and I get one of these codes "unable to download indexphp from autoappmart.com
unable to open this internet site. The requested site is either unavailable or cannot be found."
ID10T error on my part, I got it to load.
No, there is no baud restriction, just about all plugins use the data that rr supplies. Could be a corrupt port driver being flaky, causing issues for xport. Or try a different xport version.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
