View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2151
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Look in your menu.skin file, you should have this line for the "Menu" btn:
    Code:
    B10,0,526,101,73,"DFX_MainMenuNext",@SetMenuScreenLimit@
    You should also have these two lines in your Exectbl.ini file:
    Code:
    "SetMenuScreenLimit","SETVAR;MyNumOskLine;Number of Menu Screens (1-6)||NUMOSKTOCMD;MainMenuLimit;SetMenuScreenLimitCont"
    "SetMenuScreenLimitCont"," ||SAVETOSKIN;MainMenuLimit;$MainMenuLimit$"
    For the next update for 5.1.2, I have added a "+" symbol to menu#1 "Menu" btn as well, to show it has a P&H function.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #2152
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    On second thought, after looking at the code, I better wait for the update! It's amazing how advance/complex the skin has become. Ya'll are geniuses..!
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #2153
    Mar 2008
    Haven't used the skin since v4... Installed 5.1.2 - ImageViewer buttons don't work (only the Browse button works).. Do work in Carwings and standalone imageviewer.
    Is there an easy fix?
    Thanks!
    Quote Originally Posted by RAWPWR View Post
    Did anyone have any problems with ImageViewer lately? For some reason bottom buttons don't work for next/prev, slideshow etc. I do see all my pics listed, so setup in ImageViewer Config.ini is correct, or did I miss something else? Also ImageViewer doesn't close after RR/DFX is closed.
  4. #2154
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Just checked here and no issues, all of the btns work and when I exit that screen, ImageViewer closes. (Tested on XP ATM)
    look at the debug.txt and see if you see anything out of the ordinary or attach it and either I or someone else might have some more ideas.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #2155
    Mar 2008
    Hi Blue,
    Looks like the background image gets in front of the imageviewer or something like that. Here's a portion of the debug.txt:
    5/14/2012 8:00:02 AM: Executing: LOAD;ImageViewer.skin;ImgVwr;C:\Program Files\RideRunner\ImageViewer\ImageViewer.exe;ImgVw r
    5/14/2012 8:00:03 AM: Shell: "C:\Program Files\RideRunner\ImageViewer\ImageViewer.exe"
    5/14/2012 8:00:03 AM: Enter Exec: True, imageviewer.skin, , False
    5/14/2012 8:00:03 AM: Que Exec: True, imageviewer.skin, "ONSCREENCHANGE", False
    5/14/2012 8:00:03 AM: Que Exec: True, imageviewer.skin, "TASKBAROFF", False
    5/14/2012 8:00:03 AM: EXECTBL Translation: TASKBAROFF -> SHOWWINDOW;!Shell_TrayWnd;FALSE||SETVAR;TRASHBAR;1
    5/14/2012 8:00:03 AM: Executing: SHOWWINDOW;!Shell_TrayWnd;FALSE
    5/14/2012 8:00:03 AM: Que Exec: True, imageviewer.skin, "SETVAR;TRASHBAR;1", False
    5/14/2012 8:00:03 AM: Executing: SETVAR;TRASHBAR;1
    5/14/2012 8:00:03 AM: Leave Exec: False, imageviewer.skin, SETVAR;TRASHBAR;1, False
    5/14/2012 8:00:07 AM: Enter Exec: False, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:07 AM: Que Exec: True, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:07 AM: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    5/14/2012 8:00:07 AM: Executing: PLAYSOUND;D:\My Documents\RideRunner\Skins\Copy of DFX5\ButtonPress.wav
    5/14/2012 8:00:07 AM: Que Exec: True, imageviewer.skin, "SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:07 AM: Executing: SENDMSG;Rcvr_ImageViewer;n
    5/14/2012 8:00:07 AM: Leave Exec: False, imageviewer.skin, SENDMSG;Rcvr_ImageViewer;n, False
    5/14/2012 8:00:13 AM: Enter Exec: False, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;b", False
    5/14/2012 8:00:13 AM: Que Exec: True, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;b", False
    5/14/2012 8:00:13 AM: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    5/14/2012 8:00:13 AM: Executing: PLAYSOUND;D:\My Documents\RideRunner\Skins\Copy of DFX5\ButtonPress.wav
    5/14/2012 8:00:13 AM: Que Exec: True, imageviewer.skin, "SENDMSG;Rcvr_ImageViewer;b", False
    5/14/2012 8:00:13 AM: Executing: SENDMSG;Rcvr_ImageViewer;b
    5/14/2012 8:00:13 AM: Leave Exec: False, imageviewer.skin, SENDMSG;Rcvr_ImageViewer;b, False
    5/14/2012 8:00:19 AM: Enter Exec: False, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:19 AM: Que Exec: True, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:19 AM: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    5/14/2012 8:00:19 AM: Executing: PLAYSOUND;D:\My Documents\RideRunner\Skins\Copy of DFX5\ButtonPress.wav
    5/14/2012 8:00:19 AM: Que Exec: True, imageviewer.skin, "SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:19 AM: Executing: SENDMSG;Rcvr_ImageViewer;n
    5/14/2012 8:00:19 AM: Leave Exec: False, imageviewer.skin, SENDMSG;Rcvr_ImageViewer;n, False
    5/14/2012 8:00:20 AM: Enter Exec: False, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:20 AM: Que Exec: True, imageviewer.skin, "ONBTNPRESS||SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:20 AM: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    5/14/2012 8:00:20 AM: Executing: PLAYSOUND;D:\My Documents\RideRunner\Skins\Copy of DFX5\ButtonPress.wav
    5/14/2012 8:00:20 AM: Que Exec: True, imageviewer.skin, "SENDMSG;Rcvr_ImageViewer;n", False
    5/14/2012 8:00:20 AM: Executing: SENDMSG;Rcvr_ImageViewer;n
    5/14/2012 8:00:20 AM: Leave Exec: False, imageviewer.skin, SENDMSG;Rcvr_ImageViewer;n, False
    5/14/2012 8:00:22 AM: Enter Exec: False, imageviewer.skin, "ONBTNPRESS||ESC||SENDMSG;Rcvr_ImageViewer;close|| TASKBAROn", False
    5/14/2012 8:00:22 AM: Que Exec: True, imageviewer.skin, "ONBTNPRESS||ESC||SENDMSG;Rcvr_ImageViewer;close|| TASKBAROn", False
    5/14/2012 8:00:22 AM: EXECTBL Translation: ONBTNPRESS -> PLAYSOUND;$SKINPATH$ButtonPress.wav
    5/14/2012 8:00:22 AM: Executing: PLAYSOUND;D:\My Documents\RideRunner\Skins\Copy of DFX5\ButtonPress.wav
    5/14/2012 8:00:22 AM: Que Exec: True, imageviewer.skin, "ESC||SENDMSG;Rcvr_ImageViewer;close||TASKBARO n", False
    5/14/2012 8:00:22 AM: Executing: ESC
    5/14/2012 8:00:22 AM: Enter Exec: True, menu2.skin, , False
    5/14/2012 8:00:22 AM: Que Exec: True, menu2.skin, "ONSCREENCHANGE", False
    5/14/2012 8:00:22 AM: Que Exec: True, menu2.skin, "SENDMSG;Rcvr_ImageViewer;close||TASKBAROn", False
    5/14/2012 8:00:22 AM: Executing: SENDMSG;Rcvr_ImageViewer;close
    5/14/2012 8:00:22 AM: Que Exec: True, menu2.skin, "TASKBAROn", False
    5/14/2012 8:00:22 AM: EXECTBL Translation: TASKBAROn -> SHOWWINDOW;!Shell_TrayWnd;True||SETVAR;TRASHBAR;0
    5/14/2012 8:00:22 AM: Executing: SHOWWINDOW;!Shell_TrayWnd;True
    5/14/2012 8:00:22 AM: Que Exec: True, menu2.skin, "SETVAR;TRASHBAR;0", False
    5/14/2012 8:00:22 AM: Executing: SETVAR;TRASHBAR;0
    5/14/2012 8:00:22 AM: Leave Exec: False, menu2.skin, SETVAR;TRASHBAR;0, False
    5/14/2012 8:00:24 AM: Enter Exec: False, menu2.skin, "ONBTNPRESS||EXITMENU", False
    5/14/2012 8:00:24 AM: Que Exec: True, menu2.skin, "ONBTNPRESS||EXITMENU", False
  6. #2156
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Trying to hash some things out for an install for my "Deckputer". RRPandora giving me some crudential issues now. Worked good for a day. That's besides the point. My issue is Net Radio. I have Shoutcast installed in winamp. That's all it used to take. Hit "Net Radio" and you're off. Now nothing works. Pressing station buttons does nothing, and trying to add stations from the "Top 10 Genre" option also does not load any data. Is this using the RRShoutcast plugin now? I installed RRShoutcast yet have not had any luck still. What should I be ding here to get the net radio going? Thanks.
  7. #2157
    Constant Bitrate besjr69's Avatar
    Feb 2011
    I've fixed the issue on my PC with RR locking up using DFX or Carwings. The issue was with Winamp. Install the resumer plugin for Winamp and it should fix the problem. This has been verified on two separate PCs with the same issue.
    Bobby
    Sent from my iPhone using Tapatalk
  8. #2158
    Mar 2008
    Any ideas? Anyone?
    ImageViewer doesn't work in my installation (fresh).
    I can browse to a folder and select, then ImageViewer shows me the first image and that's it - "Prev", "Next", "Zoom" and "Slide Show" all produce empty DFX background.
    I have an impression that the buttons do work but the background gets in front of the images
    Quote Originally Posted by maxthebuilder View Post
    Hi Blue,
  9. #2159
    Jul 2009
    BEAVERTON, OREGON
    RR Dynamic Menus for DFX5.
    I know that DFX5 already pretty much has this but I thought integrating the New RR Dynamic Menu would make things with other skins easier. Ended up not being that much work.
    Menu.lst file created using 5.1.2 Skin.ini file.” Icon path” is MenuIcons.
    Note: for plug-ins using this, the path is coded for Icons not MenuIcons. There is already an Icons folder that has some icons in it.
    Created new MenuItemSet.skin, looks the same as the DFX5 MenuButton_Manager.skin updated for RR dynamic Menu
    Added RR Dynamic Menu,Menu2,Menu3,Menu4,Menu5,Menu6 created old DFX Menu button, labels, and indicators commented out.
    Attached Files Attached Files
  10. #2160
    Nov 2007
    PA
    Quote Originally Posted by besjr69 View Post
    Bobby
    Can you explain further>? I am having an issue where Carwings and FX no matter whcih, RR is opening two instances of Winamp. Was that happening to you?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
