Never had that issue. Seems you need to check RRConfig player settings. Also cut debug ON and see what is happening during the load sequence. Mine used to stop at Audio Player.
Bobby
Sent from my iPhone using Tapatalk
Printable View
Bobby
The resumer plugin did not solve my lockup issues, I looked to see if there were 2 instances of winamp, but there is only one. I'm running the March release of RR.
Try this:
-Open up Winamp from the desktop.
-Select any music and play it at least 1min (give resumer time to save the status)
-Close Winamp
-Reopen Winamp to ensure resumer worked
Open up RRConfig and set the following:
-Debug:Checked
-Players & Path: Select Winamp in the drop down and Check the "Single player instance" option
-Save and Exit
-Open up DFX or CarWings
Bobby
This two WA instances is b/c you have either Mitch's WebRadio plugin installed or are using one of the Line-In Player settings in RR, causing it to open and use them both. Also note, that for the latter, there is also an option to use the line-in while only running a single instance of WA....
Somebody do me a favor and let me know if the "aspect ratio" button work when playing a video..
Thanks in advance.
just a point of interest, i would NOT install the resumer plugin to winamp...
Wondering if someone can shed some light on my Internet Radio Woes in DFX5. The stations by "State" work fine. But any genre selection does not pull up any stations and is blank. I have "Updated Stations from Internet" yet nothing at all shows in in the genre selection. The list 40's, 50's 60's etc is there but no correlating results.
It's been like this for a couple months now. When it started happening I tried reverting the internet radio files to older versions but didnt make a diference. You can see the stations on the ini file but for some reason it wont display them on the DFx inetRadio screen. Mine has a couple "broken" radio buttons caused by trying to set them to stations. Havent had time to figure out how to manually assign buttons by editing the config files
