View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2161
    Constant Bitrate besjr69's Avatar
    Feb 2011
    Never had that issue. Seems you need to check RRConfig player settings. Also cut debug ON and see what is happening during the load sequence. Mine used to stop at Audio Player.
    Bobby
    Sent from my iPhone using Tapatalk
  2. #2162
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    The resumer plugin did not solve my lockup issues, I looked to see if there were 2 instances of winamp, but there is only one. I'm running the March release of RR.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  3. #2163
    Feb 2011
    Try this:
    -Open up Winamp from the desktop.
    -Select any music and play it at least 1min (give resumer time to save the status)
    -Close Winamp
    -Reopen Winamp to ensure resumer worked
    Open up RRConfig and set the following:
    -Debug:Checked
    -Players & Path: Select Winamp in the drop down and Check the "Single player instance" option
    -Save and Exit
    -Open up DFX or CarWings
    Bobby
  4. #2164
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Dougw133 View Post
    Can you explain further>? I am having an issue where Carwings and FX no matter whcih, RR is opening two instances of Winamp. Was that happening to you?
    This two WA instances is b/c you have either Mitch's WebRadio plugin installed or are using one of the Line-In Player settings in RR, causing it to open and use them both. Also note, that for the latter, there is also an option to use the line-in while only running a single instance of WA....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2165
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Thanks, I'm not using HD radio or any other line in source. I'll double check RRconfig.
  6. #2166
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Somebody do me a favor and let me know if the "aspect ratio" button work when playing a video..
    Thanks in advance.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  7. #2167
    MySQL Error
    Oct 2004
    just a point of interest, i would NOT install the resumer plugin to winamp...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #2168
    Nov 2007
    PA
    Quote Originally Posted by JohnWPB View Post
    Ok, looks like I have it all just about working. Between the "Genre Top 10's" and the stations by state, there are just over 8,000 stations to choose from!
    I added a folder "_My Saved Stations" to the list, that you can put any custom stations in. This will not be overwritten by any of the auto station up-daters, skin patches or installers.
    I also reworked all of the Internet Radio screens, to have the full size top bar to display the artist, song and station when selecting / listening to Internet Radio Stations.
    Wondering if someone can shed some light on my Internet Radio Woes in DFX5. The stations by "State" work fine. But any genre selection does not pull up any stations and is blank. I have "Updated Stations from Internet" yet nothing at all shows in in the genre selection. The list 40's, 50's 60's etc is there but no correlating results.
  9. #2169
    Mar 2004
    Greenacres, WA
    That's my experience also.
  10. #2170
    Oct 2007
    It's been like this for a couple months now. When it started happening I tried reverting the internet radio files to older versions but didnt make a diference. You can see the stations on the ini file but for some reason it wont display them on the DFx inetRadio screen. Mine has a couple "broken" radio buttons caused by trying to set them to stations. Havent had time to figure out how to manually assign buttons by editing the config files
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
