Any luck for next sunday?
Printable View
Is there an easy way to delete a song from a virtual disk? Is the manage playlist function supposed to be able to work with the virtual disks? This is a constant struggle for me as I'm cleaning up my music libraries and constantly getting dead links in my virtual disks, as well as changing my mind about songs added.
For some of my disks, it takes a while to build them manually, and having to clear and restart is a daunting task.
IIRC media manager should be albe to remove the songs if you rescan the database. If you mean physically delete them from the disk, I know there was a discussion about that over in the media database thread. I can't recall the results of the discussion though, sorry.
Doing either a full rescan or using the perm song del btn will remove all references to missing media. Off the top of my head, I don't think that there is a way to del a single song from a vdiskw. I'll recheck my notes and get back to ya
Thanks. It was the later (del a single song from a vdiskw) that I was most interested in.
Ok, yet another Agility 2 SSD failed on me, so re-installed from scratch yet again...
Checked a few pages back, but those menu.skin and exectbl.ini lines exist, but I still cant get more than the one single menu screen when clicking or holding the button and trying to tell it to use more.
Probably yet something else I've forgotten that's funky with doing a win7 64bit install, dll needing to be manually registered or the like. Help?
Code:6/13/2012 8:57:24 PM: Start -- Version: 6/1/2012
6/13/2012 8:57:24 PM: OS Type: Windows 7
6/13/2012 8:57:24 PM: FileManager: FileMode = Profile
6/13/2012 8:57:24 PM: FileManager: mypath = C:\Program Files (x86)\RideRunner\
6/13/2012 8:57:24 PM: FileManager: ProfilePath = C:\Users\wayne\Documents\RideRunner\
6/13/2012 8:57:24 PM: Start Sequence: Starting Player...
6/13/2012 8:57:24 PM: PLAYER: Initialization creating object
6/13/2012 8:57:24 PM: PLAYER: Started
6/13/2012 8:57:24 PM: PLAYER: Winamp Version: 5.62
6/13/2012 8:57:24 PM: PLAYER: Initialization complete
6/13/2012 8:57:24 PM: Start Sequence: Starting Radio Device...
6/13/2012 8:57:24 PM: Start Sequence: Starting Serial Devices...
6/13/2012 8:57:24 PM: Start Sequence: Starting Mixer...
6/13/2012 8:57:24 PM: VMC---> Set object successful
6/13/2012 8:57:24 PM: VMC---> SOURCE: Mixer line #1: "Speakers"
6/13/2012 8:57:24 PM: Start Sequence: Starting Speech...
6/13/2012 8:57:24 PM: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
6/13/2012 8:57:24 PM: Plugin Manager: loading Global Plugins...
6/13/2012 8:57:24 PM: Plugin Manager: Plugin Found: InetRadioLabels
6/13/2012 8:57:24 PM: Plugin Manager: Plugin loaded (Global): InetRadioLabels
6/13/2012 8:57:24 PM: Plugin Manager: Plugin Found: RRExtended
6/13/2012 8:57:24 PM: Plugin Manager: Plugin loaded (Global): RRExtended
6/13/2012 8:57:26 PM: Plugin Manager: Plugin Found: RRMediaDB
6/13/2012 8:57:26 PM: Plugin Manager: Plugin loaded (Global): RRMediaDB
6/13/2012 8:57:26 PM: Plugin Manager: Plugin Found: SkinTool
6/13/2012 8:57:26 PM: Plugin Manager: Plugin loaded (Global): SkinTool
6/13/2012 8:57:26 PM: Plugin Manager: Plugin Found: Weather
6/13/2012 8:57:26 PM: Plugin Manager: Plugin loaded (Global): Weather
6/13/2012 8:57:26 PM: Plugin Manager: Warning Plugin Weather is set to disabled, by plugins.ini file
6/13/2012 8:57:26 PM: Plugin Manager: loading Global Plugins Completed.
6/13/2012 8:57:26 PM: LoadSkin: C:\Users\wayne\Documents\RideRunner\Skins\DFX5\
6/13/2012 8:57:26 PM: Plugin Manager: loading SkinDir Plugins...
6/13/2012 8:57:26 PM: Plugin Manager: Plugin Found: DFX5
6/13/2012 8:57:26 PM: Plugin Manager: Plugin loaded (SkinDir): DFX5
6/13/2012 8:57:26 PM: Plugin Manager: loading SkinDir Plugins Completed.
6/13/2012 8:57:26 PM: Start Sequence: Pre-Loading- Loading Menu (1 / 4)
6/13/2012 8:57:26 PM: Preloading(Mode: Full): menu2.skin (Took 0.297625 seconds)
6/13/2012 8:57:26 PM: Start Sequence: Pre-Loading- Loading Menu (2 / 4)
6/13/2012 8:57:27 PM: Preloading(Mode: Full): menu3.skin (Took 0.29775 seconds)
6/13/2012 8:57:27 PM: Start Sequence: Pre-Loading- Loading Menu (3 / 4)
6/13/2012 8:57:27 PM: Preloading(Mode: Full): menu4.skin (Took 0.312875 seconds)
6/13/2012 8:57:27 PM: Start Sequence: Pre-Loading- Loading RRMedia (4 / 4)
6/13/2012 8:57:27 PM: Preloading(Mode: Full): rm_media.skin (Took 0.421375 seconds)
6/13/2012 8:57:28 PM: Enter Exec: False, menu.skin, "ONRESTORED", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONRESTORED", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINORIGWIDTH;800||SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;1024||SETVAR;SKINSHOWHEIGHT;768||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINORIGWIDTH;800
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;1024||SETVAR;SKINSHOWHEIGHT;768||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINORIGHEIGHT;600
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWWIDTH;1024||SETVAR;SKINSHOWHEIGHT;768||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINSHOWWIDTH;1024
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWHEIGHT;768||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINSHOWHEIGHT;768
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINXPOSITION;0
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;SKINYPOSITION;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;SKINYPOSITION;0
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONSTART", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "Setvar;DFXVersion;v5.1.1.R", False
6/13/2012 8:57:28 PM: Executing: Setvar;DFXVersion;v5.1.1.R
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SetVar;DFXPluginStatus;Registered", False
6/13/2012 8:57:28 PM: Executing: SetVar;DFXPluginStatus;Registered
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONLINE", False
6/13/2012 8:57:28 PM: Leave Exec: False, menu.skin, ONLINE, False
6/13/2012 8:57:28 PM: Global Hotkey: Successfully registered keycode:2112
6/13/2012 8:57:28 PM: PLAYER: Restored rrpl.m3u8
6/13/2012 8:57:28 PM: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
6/13/2012 8:57:28 PM: INFO: LoadResume() - Reading resume data from C:\Users\wayne\Documents\RideRunner\Cache\resume.ini
6/13/2012 8:57:28 PM: INFO: AudPlayerStart() - music player: PLPosition=35 TrackPosition=-2897
6/13/2012 8:57:28 PM: INFO: AudPlayerStart() - player volume should be 0: 0
6/13/2012 8:57:28 PM: INFO: AudPlayerStart() - player should be playing: PLAYING
6/13/2012 8:57:28 PM: Enter Exec: False, menu.skin, , False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
6/13/2012 8:57:28 PM: EXECTBL Translation: ONSKINSTART -> DFXDLLCHECK||PreloadCheck||ONSCREENCHANGE||ReLock||SpeedIndicatorLoader||GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "PreloadCheck||ONSCREENCHANGE||ReLock||SpeedIndicatorLoader||GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: EXECTBL Translation: PreloadCheck -> BYVAR;SKINRELOADING;<<DoPreload
6/13/2012 8:57:28 PM: Executing: BYVAR;SKINRELOADING;<<DoPreload
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE||ReLock||SpeedIndicatorLoader||GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ReLock||SpeedIndicatorLoader||GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: EXECTBL Translation: ReLock -> RunQ;$SkinPath$Scripts\DFXLocker\ReLock.exe
6/13/2012 8:57:28 PM: Executing: RunQ;C:\Users\wayne\Documents\RideRunner\Skins\DFX5\Scripts\DFXLocker\ReLock.exe
6/13/2012 8:57:28 PM: Shell: "C:\Users\wayne\Documents\RideRunner\Skins\DFX5\Scripts\DFXLocker\ReLock.exe"
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SpeedIndicatorLoader||GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: EXECTBL Translation: SpeedIndicatorLoader -> BYVAR;speedatt;<<SetSpeedvolIndStates
6/13/2012 8:57:28 PM: Executing: BYVAR;speedatt;<<SetSpeedvolIndStates
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "GreetingPlay||GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: EXECTBL Translation: GreetingPlay -> BYVAR;GreetingOnOff;DoNothing<<SpeakGreeting
6/13/2012 8:57:28 PM: Executing: BYVAR;GreetingOnOff;DoNothing<<SpeakGreeting
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "DoNothing", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "GreetingPopUp||SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: EXECTBL Translation: GreetingPopUp -> BYVAR;GreetingPopUp;DoNothing<<GreetingPopUpGo
6/13/2012 8:57:28 PM: Executing: BYVAR;GreetingPopUp;DoNothing<<GreetingPopUpGo
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SAVENSETTOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SAVETOSKIN;SKINRELOADING;0", False
6/13/2012 8:57:28 PM: Executing: SAVETOSKIN;SKINRELOADING;0
6/13/2012 8:57:28 PM: SAVETOINI: C:\Users\wayne\Documents\RideRunner\Skins\DFX5\skin.ini
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "SETVAR;DFXAUDIO;0", False
6/13/2012 8:57:28 PM: Executing: SETVAR;DFXAUDIO;0
6/13/2012 8:57:28 PM: Leave Exec: False, menu.skin, SETVAR;DFXAUDIO;0, False
6/13/2012 8:57:28 PM: INFO: AudPlayerStart() - Player.GetTrackLength: 210000
6/13/2012 8:57:28 PM: INFO: AudPlayerStart() - Player.SetTrackPosition: 2897
6/13/2012 8:57:28 PM: INFO: CheckResume() - Resuming to music player: PAUSED
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "Reset_Stars", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "RM_UpdateDiskNames", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "RM_SETLABEL;RM_PlayedCount;10||RM_SETLABEL;RM_LastPlayedDate;6/13/2012 8:56:00 PM||RM_SETLABEL;RM_SongDateAdded;6/7/2012 12:28:00 PM", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "RM_SETLABEL;RM_LastPlayedDate;6/13/2012 8:56:00 PM||RM_SETLABEL;RM_SongDateAdded;6/7/2012 12:28:00 PM", False
6/13/2012 8:57:28 PM: Que Exec: True, menu.skin, "RM_SETLABEL;RM_SongDateAdded;6/7/2012 12:28:00 PM", False
6/13/2012 8:57:28 PM: Leave Exec: False, menu.skin, RM_SETLABEL;RM_SongDateAdded;6/7/2012 12:28:00 PM, False
6/13/2012 8:57:29 PM: Enter Exec: False, menu.skin, , False
6/13/2012 8:57:29 PM: Que Exec: True, menu.skin, "RM_Rated0", False
6/13/2012 8:57:29 PM: Leave Exec: False, menu.skin, RM_Rated0, False
6/13/2012 8:57:33 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||DFX_MainMenuNext", False
6/13/2012 8:57:33 PM: Que Exec: True, menu.skin, "ONBTNPRESS||DFX_MainMenuNext", False
6/13/2012 8:57:33 PM: Que Exec: True, menu.skin, "DFX_MainMenuNext", False
6/13/2012 8:57:33 PM: Executing: DFX_MainMenuNext
6/13/2012 8:57:33 PM: Command not executed: DFX_MainMenuNext
6/13/2012 8:57:33 PM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
6/13/2012 8:57:33 PM: EXECTBL Translation: ONCOMMANDINVALID -> EVAL;RESULT;strcomp("dfxdllcheck";"$COMMANDINVALID$")||BYVAR;RESULT;ONCOMMANDINVALID_CONT<<DfxPlugin_Err
6/13/2012 8:57:33 PM: Executing: EVAL;RESULT;strcomp("dfxdllcheck";"DFX_MainMenuNext")
6/13/2012 8:57:33 PM: Que Exec: True, menu.skin, "BYVAR;RESULT;ONCOMMANDINVALID_CONT<<DfxPlugin_Err", False
6/13/2012 8:57:33 PM: Executing: BYVAR;RESULT;ONCOMMANDINVALID_CONT<<DfxPlugin_Err
6/13/2012 8:57:33 PM: Que Exec: True, menu.skin, "ONCOMMANDINVALID_CONT", False
6/13/2012 8:57:33 PM: EXECTBL Translation: ONCOMMANDINVALID_CONT -> ONCOMMANDINVALID
6/13/2012 8:57:33 PM: Executing: ONCOMMANDINVALID
6/13/2012 8:57:33 PM: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
6/13/2012 8:57:35 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||TASKBAROn||MINIMIZE", False
6/13/2012 8:57:35 PM: Que Exec: True, menu.skin, "ONBTNPRESS||TASKBAROn||MINIMIZE", False
6/13/2012 8:57:35 PM: Que Exec: True, menu.skin, "TASKBAROn||MINIMIZE", False
6/13/2012 8:57:35 PM: EXECTBL Translation: TASKBAROn -> SHOWWINDOW;!Shell_TrayWnd;True||SETVAR;TRASHBAR;0
6/13/2012 8:57:35 PM: Executing: SHOWWINDOW;!Shell_TrayWnd;True
6/13/2012 8:57:35 PM: Que Exec: True, menu.skin, "SETVAR;TRASHBAR;0", False
6/13/2012 8:57:35 PM: Executing: SETVAR;TRASHBAR;0
6/13/2012 8:57:35 PM: Que Exec: True, menu.skin, "MINIMIZE", False
6/13/2012 8:57:35 PM: Executing: MINIMIZE
6/13/2012 8:57:35 PM: Enter Exec: True, menu.skin, "ONMINIMIZED", False
6/13/2012 8:57:35 PM: Queued: "ONMINIMIZED"
is there any way/settings i can set up to have the ablity to plug and play music from my Iphone?
just got the new system, some im a rookie to say the least!
Thanks alot
Im Running DFX5 and Road/Ride Runner
First let me say the SEARCH FEATURE SUCKS! Now, i'm testing a new build and i noticed the buttons in iguidance don't respond. Buttons like "zoom" "3D" "toggle north" "IG menu" etc have no effect in any layout.
Just wondering if somebody is seeing the same?
I did modify the skin a bit but i don't think i did anything that would mess with iguidance - or did I?
