View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2191
  2. #2192
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    Have you changed the version of iGuidance?
    It may be the newer versions have different (or not at all) shortcut keys.
    No, same old IG3. Guess i'll have to install a fresh copy of DFX and see if it work.
    Thanks anyway.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #2193
    Constant Bitrate overlander's Avatar
    Feb 2008
    not all the IG buttons work for me either.
  4. #2194
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by overlander View Post
    Thanks for confirming. I installed a fresh copy (no mods) of DFX and the buttons still don't work so it's something in the skin. Now i know where to concentrate the troubleshooting.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  5. #2195
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'm surprised that no one asked if you have updated your RR? There was some work done with imbeded windows, and that could have effected the sendkey cmds that are used in those screens possibly... None of those have changed for the last several versions of DFX that I know of..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #2196
    Sep 2006
    War-Town, GA.
    You're on the right track (as usual), i'm on 6/1/2012 and the buttons DON'T work in any skin (DFX4, iDrive, Void) so it probably IS in RR itself. I'm going to post in the RR thread and see if i can catch Mitch's attention.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  7. #2197
    MySQL Error
    Oct 2004
    dfx5 has issues in the skins for IGuidance
    they need a little cleanup
    the sendkeys in bad format
    also, unknow to me, and prob anyone else, if you want to sendkey to ig, the skin must have the letters "gps" in it
    also, sendkey is weak anyway, i have coded a "sendkeyx" which will activate the embedded window 1st, then send the keystrokes
    so... clean up in dfx5 is needed, to use the new command sendkeyx, new rr as of 6/21/2012
    to have it all work with the old rr, fix the skin name for iguance_wide to have "gps" in it
    and fix up the sendkey commands in the skin
    like
    "sendkey;"{3}"
    its just
    "sendkey;3"
    no extra " and no { }
    ofcourse, this works too "activate||sendkey;3"
    but the new sendkeyx handles that all for you
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #2198
    May 2008
    Bend, OR
    It feels like blue and john have thrown in the towel on this, RR seems like such a moving target. I wonder if that's the goal kill it so no one works with it and nisau can close the opensource hole.
  9. #2199
    Sep 2006
    War-Town, GA.
    They are probably understandibly burned-out! It's time for us to help each other. "Conspiracy theory" LOL in order to shut down RR open source, all they have to do is shut-it- down! They don't need permission from anybody much less a conspiracy between John, Blue, mitch, gino to slowly kill DFX to in turn have an excuse to kill RR as well..
    And if you hadn't noticed, RR isn't REALLY open source..
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  10. #2200
    Sep 2006
    War-Town, GA.
    Iguidance fix (temporary)
    To make all the buttons work, add "ACTIVATE;IGuidance||" in front of all the sendkey commands in the external_gps.skin, external_music_gps.skin and iguidance_wide.skin to go from this: "SENDKEY;{down}" to this: "ACTIVATE;IGuidance||SENDKEY;{down}" and so forth..
    Alternatively, copy and replace the files attached into the DFX5 folder. (change .txt to .skin)
    The next release of RR will have new code that will clean-up everything. I will then update the skin files and post them.
    Thanks Mitch, Enforcer and Blue for your help.
    Attached Files Attached Files
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
