View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2211
    MySQL Error
    Oct 2004
    look, i told you i found it works too in 6/1 RR!!
    it does work!!!
    and DID work with 6/1 RR
    why that guy couldnt get it work, who knows!!!
    but when i looked at it
    i found just some minor typos...
    to test it i used your wide, and SKINTOOL, and it worked until i used SKINTOOL!
    you dont have to change DFX5, but you DO have to fix all the SKIN CODE ERRORS
    again WTF is "SENDKEY;"{3}" thats totally bad syntax!
    your skin has had many issues before... just because it works, doesnt mean its right
    now look at the skin called: EXTERNAL_GPS.SKIN
    LINE 46:
    B,2,77,72,71,"SENDKEY;"{3}",""
    it should be
    B,2,77,72,71,"SENDKEY;3",""
    and look at line 43:
    B,727,452,71,79,"SENDKEY;"{t}",""
    should be
    B,727,452,71,79,"SENDKEY;t",""
    just minor typos, thats all that has to happen
    now, if you want to be assured, that sendkeys goes to where you EXPECT it to go, in this case iGuidance
    you have to have the letters "gps" in the skin name
    this isnt new, i didnt know it myself, but this explains, why one can have an issue on
    "IGUIDANCE_WIDE.SKIN"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #2212
    MySQL Error
    Oct 2004
    you dont have to go fixing sendkey in all your files...
    but you do have to fix the poor synatx of them, the strange extra Qoute, the { around non "special keys" ie {3} , funny it works, but its invalid, google VB6s sendkeys format, things like {enter} go in {}
    also we have 3 addition ones
    {QT} for "
    {SC} for ;
    {CM} for ,
    since they need to be escaped
    and yes, the only FIX you HAVE to do for DF5, to ASSURE sendkey works, is add "GPS" to skin name
    like IGUIDANCE_WIDE_GPS.SKIN
    that like the already properlly named skins "EXTERNAL_GPS.SKIN" and "EXTERNAL_MUSIC_GPS.SKIN"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #2213
    MySQL Error
    Oct 2004
    if something doesnt work in 6/1, that worked in 1/1 lets look at it
    but I SAID, and CONTINUE to SAY, IG WORKS in DFX5 IN 6/1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    you said, you tested it, or well, something says your taking someone elses word for that
    I TESTED 6/1 with DF5 and the IG buttons WORK, execpt 1, the "repeat" button on IGUIDANCE_WIDE.SKIN, and thats coded as same as the "3d" key to send a 3
    so they both do the same thing...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #2214
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Let's take this out back..
    Can we take this out back so we don't clog-up this thread..see you at the "SENDKEYS" thread..be ready..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #2215
    Maximum Bitrate RAWPWR's Avatar
    May 2007
  6. #2216
    May 2008
    Bend, OR
    Quote Originally Posted by treetop777 View Post
    2200+ posts, clog the thread, hahaha
  7. #2217
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Getting 2 different versions of iGuidance to play well together.
    I want to get iGuidance 4 & 2011 working seperate in the skin.
    In RR config I have the Gps pointed to version 4 location.
    Then in the DFX Skin.ini the first iGuidance button (5) in my istance it is pointed to version 4 location.
    Then in the DFX Skin.ini the 2nd iGuidance button (11) in my istance is pointed to the 2011 version location.
    But no mater what one I choose it opens up version 4.
    How do I set it up to have the 2 versions working?
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  8. #2218
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Both of your "MainMenuExec_0x" lines in the skin.ini for the two versions have all the correct info? Post the two lines?
    Are you trying to run both at the same time or completely closing one before using the other as they will both have the same window title and maybe RR is always grabbing the v4 one?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #2219
    Feb 2005
    Huntsville, AL
    I am trying to keep both open so I can switch back and fourth when I need to. (Hope it's possible)
    Upon further playing around it only shows the first one opened up. If I open up 2011 and want to switch to 4.0 it still shows 2011 & vise versa. At first I thought it only opened version 4.0 but it only shows the first one opened up.
    RR config GPS path is C:\Program Files\iNav 4\iGuidance\iGuidanceUMPC.exe
    The 2 lines are:
    MainMenuExec_05=Load;$GpsScreen$;$GPSNAME$;$GPSPAT H$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;{p}{p}
    MainMenuExec_11=Load;External_GPS.skin;C:\Program Files\iNav\iGuidance\iGuidanceNPC.exe;iGuidance||A CTIVATE;iGuidance||SENDKEY;{p}{p}
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  10. #2220
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    K, I think what your having issues with is that both btns are using the same screen, try making(copy/rename) a 2nd 'external_gps.skin' file and put that in the first btns line, replacing the $GpsScreen$ with whatever you call it. Then you might have better luck.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
