View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2221
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    K, I think what your having issues with is that both btns are using the same screen, try making(copy/rename) a 2nd 'external_gps.skin' file and put that in the first btns line, replacing the $GpsScreen$ with whatever you call it. Then you might have better luck.
    Doh!!
    I guess I should of checked if I could run both versions out of RR first before wondering why it don't work.
    Both versions don't run at the same time out of RR either.
    Anyone know how to get them to?
    Or better yet someone needs to get iguidance 2011 working with entering gas station coordinates automatically like 4.0 can do.
    Thanks Blue.
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #2222
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Seems like what BlueZX3 said would work - have you tried?
    MainMenuExec_11=Load;IG2011_GPS.skin;C:\Program Files\iNav\iGuidance\iGuidanceNPC.exe;iGuidance||A CTIVATE;iGuidance||SENDKEY;{p}{p}
    Embed it into a skin other that external_GPS.skin.
    I know an old program called "skinbedder" could do it - hell, you could run them side-by-side.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #2223
    Constant Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    I've tried looking for this problem and still can't find a solution, someone on this thread asked about it but no one replied.
    I have the latest version of rr installed and digital fx 5.1.2 installed
    When i use RR with carwings, everything work with no issue, but when i load digital fx, nothing works aside from the menu button, i click on anything else, like music, global settings, it just freezes
    here is the error i get:
    error RRentertainment center has stopped working
    Apphang b1
  4. #2224
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What plugins do you have installed? RR almost never crashes like that, but plugin(s) can crash it hard like your describing. Also what OS?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2225
    Jul 2007
    orlando
    I just installed the basic RR and digital fx. i'm on win 7 64bit. when i use the carwings skin i have no problems what so ever, but the moment i try to use digital fx, anything i click on crashes it apart from the menu button. I even went back to RRConfig and switched to carwings and no problems in carwings, then switch back to digital fx and crash
  6. #2226
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by treetop777 View Post
    Hi, that might-should work but the problem now is iGuidance will not run 2 versions at the same time even out of RR. Until I can figure out how to get get both of them running out of RR I can't try the new method.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  7. #2227
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by michaelrj9 View Post
    Hi, that might-should work but the problem now is iGuidance will not run 2 versions at thw same time even out of RR. Until I can figure out how to get get both of the running out of RR I can't try the new method.
    As of iGv4 you can not run multiple copies, either same versions or diff... And I'm not sure about the addition of the coords back into the iGv2011(4.2) exe using the previous versons instructions either.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #2228
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Morpheus2010 View Post
    Attach a debug log, might have some insight to the issue... Also in that crash window, what is the "Fault Module" listed as?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #2229
    Sep 2006
    War-Town, GA.
    You're probable overthinking it or assuming facts not in evidence :-) Are you saying that when you (double) click on "iguidanceUMPC.exe" it brings up the same IG as if you had clicked on "IguidanceNPC.exe"..?
    BTW: Why would you want to run both anyway..?
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  10. #2230
    Feb 2005
    Huntsville, AL
    BTW: Why would you want ot run both anyway..?
    Like blue said (I did not know before I started posting about it) Iguidance won't run multiple copies the same version or different version it doesn't matter it will not run. This is just done in Windows not RR.
    If I open up 1 version of iGuidance then try to open another one (same version or different one) all it does is focuses on the one that is already opened.
    I wanted to run both because the newer version has the updated maps and the old version works with RRFuelPrices & gasnav to automatically enter the directions to the gas station.
    Off topic:
    I think the CarPC enviroment should start focusing on making fast-Good-reliable working emulators for Andriod & iPhones that would be taylored to the frotend uses. That would help a lot with the navigation software problem that is starting to be scarce on PC'S. Then it would open the world to tons more sfuff that could run on a CarPC.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
