View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2231
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Start another thread in the RR or GPS section..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  2. #2232
    Constant Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    Attach a debug log, might have some insight to the issue... Also in that crash window, what is the "Fault Module" listed as?
    here it is; also i attached the only debug text file i could find
    Description:
    A problem caused this program to stop interacting with Windows.
    Problem signature:
    Problem Event Name: AppHangB1
    Application Name: RideRunner.exe
    Application Version: 1.0.0.0
    Application Timestamp: 4fc8b689
    Hang Signature: 1e8c
    Hang Type: 260
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional Hang Signature 1: 1e8cabb3f5cc85d036ea010213ff1480
    Additional Hang Signature 2: 84e7
    Additional Hang Signature 3: 84e72db5e915dee48bb49e5b8ba77b73
    Additional Hang Signature 4: fdc8
    Additional Hang Signature 5: fdc8b49346dbf6b3910ac1ee40111023
    Additional Hang Signature 6: e169
    Additional Hang Signature 7: e1695081aae01b86b004de8018078835
    Attached Files Attached Files
  3. #2233
    Jul 2007
    orlando
    Here is new debug file, i changed dfx voice to damn voice and it seemed to work, no problems what so ever.now how do i get the voice option to work and the weather(its just blank nothing shows up even tho i enter in Orlando fl);wakeup & sleep command,
  4. #2234
    May 2007
    Is there a way to change the size of the pandora window? All the control buttons are cut off on top of the screen. Also what browser is being used for Pandora. I have IE set to login to the correct Pandora Account but the skin is loading the wrong Pandora Account.
  5. #2235
    Aug 2006
    Any idea why when I do a fresh install (cleaned out \program files\, \Application Data\, and \RideRunner\ in MyDocs) that I cannot long press any buttons on the screen inside of RR to change the button?
    It used to give me an error saying it was missing a skin, but that was before I did a fresh install, not it just does nothing...
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  6. #2236
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try looking at the debug log, and see what it shows is going on when you press and hold a btn.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #2237
    Aug 2006
    thanks for the reply, here's my current debug file:
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  8. #2238
    May 2008
    Bend, OR
    so are the hopes for an update pack totally dead?
  9. #2239
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by steven765 View Post
    ...............no
    <goes and crawls back under rock>
    haha
    Quote Originally Posted by iNcArCeRaTiOn View Post
    I can tell you that your problem is that you are not using the correct skin plugin dll. Your using an older one that is missing those hold commands and that is why it refuses to do anything...it doesn't know that its suppose to do something. I don't know what/how you did with your install, did you try and use one of the older "Donation Patch" installers on the skin after you installed it? If so then that is where it was replaced w/ an older version of it.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #2240
    Aug 2006
    Not that I know of? I used the download from the app mart or whatever
    https://autoappmart.com/products/DFX...RideRunner_162
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
