View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2301
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by RAWPWR View Post
    Blue,
    Ok,... I reinstalled WA ver. 5.5.8.2975, and everything is back to normal with AVS, and this ver. supports unicode.
    But I have problems with some plug-ins,,,
    ie: RRPandora, RRWebRadio.
    The visualizations don't work at all if I keep the Pandora plug loaded at start-up of RR. Doesn't matter what skin I use.
    But if I go into my plugin manager and disable Pandora, go back to music (mp3 player screen) and try to use the vis....
    They work great again.
    This probably has something to do with the facr that RRPandora opens it's very own instance of Winamp that is hidden. It's possible that when a visual is opened, it is being hidden because of that. The same for Internet Radio by Sonic. That will also open another version of Winamp. So, basically, if you have the Internet Radio and Pandora plugins installed, when you start RR, 3 copies of Winamp will be running.
    This would be something to ask Sonic, as he would know how he is starting and hiding the instances of Winamp.
    My Fiero Build Thread
  2. #2302
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Now I'm really confused???
    John,
    Does your internet radio for DFX use its own instance too? Or is it just sonic's and Mitch's that do?
    It looks like the instance for pandora is showing on the right not hidden?
    When I disable pandora the visuals work ok for mp3 and webradio,,, but when I re-enable it in plug manager again, the vis don't work. But they do work for pandora only now?
    Now this is just in your skin,,,,
    I did not enable Mitch's internet radio plug, because I use yours.
    In other skins I use Mitch's plug and the vis won't work in it either as long as I keep pandora enabled.
    You may be right, this could be the pandora plug.
    I'm adding my debug from DFX.
    Thanks John.
    Attached Files Attached Files
  3. #2303
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The one in the skin uses the RR plyr
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #2304
    Aug 2012
    Adelaide
    That looked fine.. So now, go into the skin folder and turn on the debugging for the skin plugin. Open up the skin.ini and find debugmode and set it to true, load rr again and then look in the DFX5\Plugins\DFX5 folder for the debug log and ATTACH it to a post... There are no issues with the default carwings skin loading?
    Ok I think I found the right file. There were 5 files that came up when I searched for skin.ini
    Under [MISC] I set DfxDebug=true
    Attached is the debug file, sorry I missed that last time! I can't see anything in the debug file which looks odd...
    There are no issues with the default skin loading, just having issues with media stuff.
  5. #2305
    May 2007
    RR uses its own instance also?
    I can also see my mp3s playing back in Winamp's song title window after minimizing RR.
    .....So does that mean that RR is using Winamp for playback of my music or not?
    Sorry I'm just trying to get a hold on this AVS problem not working when switching between plugs and music players, without having to disable a plug to use the AVS eye candy.
    I don't know if this will work but,,,,
    maybe a solution like disable/enable automatically the pandora/webradio plug upon entering music (mp3) player screen.
    thx.
  6. #2306
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    RR will use whatever player you have set to use WMP/iCrap/Winamp/Foobar/ect for its main audio backend player. Both the RRPandora and Mitches InternetRadio plugins both use a seperate player instance, and i can't even tell you if they hard coded them to winamp only or they go by what ever player you have set in RR???? I'm not the one to ask on either one of those fronts. And Mitch would just say...easy solution, just use visu's. LOL
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #2307
    MySQL Error
    Oct 2004
    dont use visu's
    pandora and my webradio use WINAMP, WINAMP is required
    (nothing to do with rr's use of winamp, but i bet somethings maybe not as smooth)
    also visu handling is tricky to begin with... i cant say if it works right in pandora...
    i had to put LOTS of code to get it working in RRWebRadio
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #2308
    May 2007
    Bummer,
    Ok,..... I'll only use visuals when playback of stored music, still going to have to disable Pandora to use this feature though. Oh well.
    "Maybe automatically disable/enable Pandora when entering/exiting music player screen might work?"
    I guess I'll ask sonic if this is possible to achieve,,,,,
    so the AVS can run fluid entering/exiting music, and the Pandora plug without having to go into plugin manager to disable it.
    Thanks Mitch.
  9. #2309
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    BTW... is someone ^ trying trying to be a "wanna be mac user" LOL Sorry, I just now seen your post above w/ the DT picture on my DT.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #2310
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Posted back on Page 184 about RRfusion. Doesn't work anymore with DFX for me. Works fine with carwings. The brain isn't connecting with DFX anymore.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
