View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2321
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    The only reason would be the dfx5.dll, check the rr log and see if you get an unrecognized cmd called dfx5nextmenu of the sort as that is the cmd on all the menus and the dll uses the var set by the setting to either go to next one or back to the first one
    I do get the following error....
    Que Exec: True, menu.skin, "DFX_MainMenuNext", False
    Executing: DFX_MainMenuNext
    Command not executed: DFX_MainMenuNext
    Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    EXECTBL Translation: ONCOMMANDINVALID -> EVAL;RESULT;strcomp("dfxdllcheck";"$COMMANDINVALID $")||BYVAR;RESULT;ONCOMMANDINVALID_CONT<<DfxPlugin _Err
    I have attached the debug file as well. Thanks for your help.
    **Edit: I was able to figure out what to do. I had to re-read the dfx dll plugin check section again...I just ran the regme.bat file and that work!
    Gee
  2. #2322
    Registered User
    Sep 2012
    Hello everyone. I am in the software stage of building my first car pc, and I have run into a problem that I can not find the answer to.
    I am running windows 7 32 bit with all updates and .net 4. I installed the latest edition of RR. I am attempting to get rr pandora to run. I have installed the app from the app mart, but it does not show up under plugins in RRconfig. When running the DFX skin when I press the pandora button it goes to the pandora website and has no DFX buttons and is asking for login info. I am experiencing the same thing in the stock Carwins skin. I have been searching the threads for days and can not find an answer. Any help will greatly be appreciated.
    P.s. This skin is awesome!!
  3. #2323
    Mar 2011
    Ohio
    OK, I've got the latest DFX 9/1/12. I updated using the Built-in updater.
    I no longer have playlists showing up while I go to the "Manage Playlist" screen. The skin that is loaded is audioplaylistload.skin. The last line shown in Skintool is SETPATH;D:\Music\Playlists\ That's my playlist path.
    I have Win7 64Bit. I've tried carwings, and I see playlists.
    I've checked the playlists path. I've checked to ensure that the playlist file type .m3u is included in the Audio file types. I'm using RR 8/31/12.
    Anybody got any ideas?
  4. #2324
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Mmmm... I would have said that maybe your playlists are m3u8's but you said you see em in carwings, so that can't be it. I just checked here (W7 32) and I get my playlists. Open up that skin file and see if it looks OK. You get lists in other screens right?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #2325
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by lovefd1003 View Post
    The pandora that comes in the skin, is/was our attempt to add it to the list of features of the skin, long before RRPandora was around. That is why its taking you to the site, via an embedded app. I have briefly messed with the RRPandora plugin and have it working in the carwings skin but we have yet to skin it. I just also found an issue with it and i'll report it to sonic.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #2326
    Mar 2011
    Ohio
    What other list are you talking about? Earlier today a did a rescan on the database.
    Currently since I can't see playlists, to open music I go to Music:Browser, then select a folder, because that's what mode it is in. Then I hit "play select", and it plays the folder. If there is a folder (Artist) that has several CD's then if I hit "Sel" on the left side, I see all their albums (folders). But if I hit "Sel" on one of the albums I get an empty list. Tha might be because I'm in folder mode. If I change "Browse Mode" to "Songs", it queries the database, then comes back with a list of songs. I can tell by the way my folders are arranged that it is not all the songs in the database. It's only the first song from each album.
  7. #2327
    Registered User
    Sep 2012
    Thanks Blue. I will continue to trouble shoot in Carwings, and maybe post in the RRPandora thread. Y'all rock!!!!
  8. #2328
    Aug 2006
    I'm having a few problems still with this skin, even though it's the skin I'd rather use over any other
    1)
    How do I backup the 1-5 rating playlists?
    I use robocopy to sync my music folder over my network with my NAS and it seems to reset my 1-5 playlists after doing this because the folder changes so much it requires me to rebuild the database. Are there playlist files I can backup or no?
    2)
    Also, why does the layout type keep defaulting to the album cover? I change it to the Mazda logo with the Logo + Compass layout and it always defaults after rebooting or power down and turning it back on later
    3)
    I still can't long press a button on the main screen to change it to something else. I keep getting the menu error (this started happening after a "fresh" install, even though I know the installers for the riderunner program and DFX aren't quite bug-free...
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  9. #2329
    Mar 2011
    Ohio
    OK, looking at the audioplaylistload.skin file. I notice at the bottom under [Lists] there is a line:
    SD,00,00,32,32,"$PlaylistPath$","$AUDIOFILES$",
    So in skintool, while on that screen I go to "Variable" and type in "PlaylistPath" then hit "Get Contents". It returns "D:\Music\Playlists", which is my playlist path. So then I type "AUDIOFILES" and hit "Get Contents" and it gives me "$audiofiles$.cda. Is that correct? I expected to see ".m3u,.m3u8,.mp3,.wma" which is what is in my "Audio File Types" in my "Audio Player and Paths" screen in RRConfig.
    Does this give any clues?
  10. #2330
    Mar 2011
    Ohio
    I did the same thing in Carwings. AUDIOFILES there returns ".m3u,.m3u8,.mp3,.wma" as expected.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
