View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2351
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by cd36 View Post
    One time I added a couple artists to my current playlist and they came in fine in order. I then wanted to play them random so I changed the list sort to randomized. It started playing random but what DFX said was being played didn't actually match what was being played.
    I encounter this every now and then also. Usually, I can just click go to the music screen and hit next song and it straightens things out. Do you by any chance have your menu layout set to display the playlist on the menu screens?
  2. #2352
    Mar 2012
    I did hit next and it seemed to play some correct songs but some were incorrect too. I'll try it again and see if it works better I only tried it once.
    I did have the main screen showing the playlist but changed it to show album art on this trip.
    Sent from my HTC One X using Tapatalk 2
  3. #2353
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Thumbs up
    I was board today and threw together some "RRPandora" skin files, so I can use this in DFX.
    Just unzip and drop in DFX folder.
    EDIT: I made a few changes, added color to buttons, DS, etc.
    Plus I also swapped the song title and album title. Looks better.
    Enjoy.
    Attached Files Attached Files
    Last edited by RAWPWR; 10-29-2012 at 09:37 AM. Reason: Forgot To Add Slider PNG File,....ooopsy.
  4. #2354
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    I am having occassional DFX skin freeze issue on startup. How do i disable DFXVoice ?
    Intel D945GCLF2, Lilliput 629GL-70NP, GTop MTK GPS, Road Runner, DFX4, Winamp 5.13+Console+VST->HotAudio DAC->NXS 400.4 + NXS400.2 DSP Amplifiers + DSP Software Processing->Dynaudio 340 3 Way Active
  5. #2355
    May 2007
    I think you have to go in plugin manager to disable?
  6. #2356
    May 2007
    If anyone is having problems....I forgot to mention that you must change a line in the DFX Exectbl.ini file.
    In the DFX "Exectbl.ini" change the line :
    "Pandora","Load;Pandora_Radio.skin;PanRadio;$SkinP ath$Scripts\PandoraRadio
    To: "Pandora","RRPANDORA"
    Then go to button editor and make sure that your button is Pandora,,,... not Pandora Eb. (???)
    click on button and make sure that "RRPANDORA" (without quotes) is listed there, and not ||Pandora.
    And all should work now.
  7. #2357
    Constant Bitrate overlander's Avatar
    Feb 2008
    Question to all. I'm interested in adding SiriusXM radio to my carpc, but new to sat radio. How are the sat radios connected to the pc to control it from DFX, and which radios are compatible with this setup? I have not signed up for the service yet nor have I bought the radio hardware. If this has been covered, please point me there. thanks
  8. #2358
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    This:
    http://store.mp3car.com/MJS_SC_C1_US..._p/sat-011.htm
    gets connected via USB to the PC and this:
    http://www.bestbuy.com/site/SIRIUS+-...c-c1&cp=1&lp=1
    via an included cable with the first device.
    The audio from the first device connects to the line-in on your sound card.
    You connect the vehicle 12v power to the first device, it powers the second device from there.
    Plug in the antenna included with the second device and point to the sky and your golden.
    I've had this setup for several years now and it works excellent.
  9. #2359
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I'm trying to configure DFX with GMPC but here are my issues:
    If GMPC is not open first or manually opened after its selected in DFX, the empty skin only comes up.
    I set up path & window name under skin.ini using external.
    Here is what it looks like if I open it manually, is this properly embedded?
    Also once at this point, if I go to use the OSK, it opens and I can select keys but I don't know how to close it when I am done. I don't know if it is inputting any data because of course the address box of GMPC is under the keyboard at this point.
    Any help would be greatly appreciated.
  10. #2360
    Feb 2008
    thanks for the xm info!
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
